intake for a 470 street strip motor
#1759484
02/21/15 01:28 AM
02/21/15 01:28 AM
Posts: 916 Arizona
Chucklehead
Arizona
Which intake would be better for street strip use the eddy RPM or a holley street dominator. Have not decided on the cam yet. auto with 373 going into a ebody. cnc ported rpm heads
Still Broke
Re: intake for a 470 street strip motor
[Re: Chucklehead]
#1759485
02/21/15 01:43 AM
02/21/15 01:43 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
According to every dyno test and article I've ever seen, you can't beat the RPM. I have one on my 451, and although Its the only manifold I've tried I'm pretty happy with the crisp throttle response and it pulls to 6500 and above.
[Re: Chucklehead]
#1759488
02/21/15 12:36 PM
02/21/15 12:36 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The cross over point in torque is about 5,000 rpm for a switch from the RPM to a good single plane, so unless you are going to use a very high stall converter and a fairly large cam, then the RPM.
[Re: gregsdart]
#1759491
02/21/15 12:44 PM
02/21/15 12:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
and from the gear I would say this is mostly a street car.... RPM
[Re: AndyF]
#1759494
02/21/15 04:03 PM
02/21/15 04:03 PM
StealthWedge67
Puyallup, WA
If I was buying all new parts I'd use a Mopar M1 4500 intake with a dual pattern Holley 750 DP carb.
Andy, I own a few of your books and hesitate to question anything you reccomend, but a 750 cfm carb on a 470 cube mill with aftermarket heads? Seems pretty conservative. Especially with the M1 single plane intake; it would seem that in order to make the single plane pay off, we would clearly need to take advantage of some upper end HP? Won't 470 cubes outrun the 750 by the time the M1 gets into its wheelhouse??? Mathmatically, at 85% V.E., a 470 needs 750cfm at 6500. This seems to perhaps support your choice, but I'd hate to limit the motor at the entry point like that, knowing that an 850 will run great and give you more ability to breath and make HP up top. (???)
[Re: StealthWedge67]
#1759495
02/21/15 05:20 PM
02/21/15 05:20 PM
Posts: 31,048 Oregon
AndyF
OP seems to have more of a street engine than a race engine so the 750 would work better 90% of the time.
If the car spends all of its time on the street then I'd use a Performer RPM with a 800 cfm Edelbrock carb. I ran that setup on my low deck 470 and made enough power to run mid-11's in my '65 Coronet. (with HP manifolds)
[Re: 383man]
#1759497
02/22/15 03:11 AM
02/22/15 03:11 AM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
RPM on my lo deck 512 Works great and pulls to 6000ish with Stealth heads.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
