Re: Car hoist?????
[Re: MR_P_BODY]
#1758982
02/20/15 09:56 PM
02/20/15 09:56 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I just bought and installed an Ammco 9000# two post lift, wish I'd done it years ago.
Looking at the two post. Easier to work on vehicle. Plus I'm sorta leaning towards the Bendpak. Now for a garage that is 24" wide and 36" deep, where is the best place to put it? I'm thinking as far back as possible to either side keeping enough room to work around it. Thanks for the input Matt
I mounted mine straight in from the big door, towards the back... I have about 3' past the end of my truck on the hoist... on the right side is my machine shop and office area.. left of the hoist has my 38 in it and cabinets
So Mike, I take it that your shop is 24x36? My door will be at the front like yours but I want a smaller door at the back left for riding lawn mover snow blower ect... With the hoist centered, do you have enough room around it? Matt
Mine is 32' deep and 36' wide.. yes I can get around it easy..the right 1/3 of the building is my machine shop and office.. the left 1/3 is car storage and cabinets and my big buffer and blast cabinet.. also my welding bench is on the machine shop side (thats 40"x 7')... you NEVER have enough room Also.. what will you do for heat... I highly recommend the floor heat... works great and its cheap to run
24x36 will be the limit if the minor variance gets approved. Now I'm thinking I'll have to stuff it to a corner to get it out of the way and go with Asymmetric to move it more out of the way. Will be going radiant. NG or propane?
Re: Car hoist?????
[Re: MattW]
#1758983
02/20/15 10:04 PM
02/20/15 10:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Mine is NG.. thank GOD we have NG here... I looked at a house with a BIG shop/garage but it was propane and I passed
Re: Car hoist?????
[Re: Stanton]
#1758984
02/20/15 11:37 PM
02/20/15 11:37 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
"4-post lifts are for storage - useless for working on cars. How would you do a brake job on a 4-post lift ???? " NOT,,,,,,,, I have the hydraulic jack which makes brake and suspension work easy,,,,,10 seconds and the front end is is off the ramps and easy to work on. I have the bendpak 4 post 9 K pound lift and have no regrets. Jack is low profile and even clears the 10 qt Charlie's oil pan on the race car
Re: Car hoist?????
[Re: plycuda]
#1758986
02/21/15 12:45 AM
02/21/15 12:45 AM
MR_P_BODY
I look at it the other way. my 4 post makes it easy to do anything. I jack it up with the air jack and I have a table under it when I'm doing the brakes. then when I want to work on my race car it's sitting at ride height and I can check and do anything. check 4 Link, string line it. mine is a bendpak 14K.I got that one because it's wide so my 1 ton dually can drive on easy. it's probably a little more money with the jack but I like the piece of mind to that I don't worry about anything happening that it could fall off.
They both have their place and I'm sure the OP will buy what he wants.... but I look at what shops have that work on cars... thats a 2 post... unlike the one I have with the floor plate.. I have a wooden ramp to do a trans.. if I had a open bottom one it would be great... even on the one I have now I roll my cart under it to work from... when I want the axle up in place I have a set of wood blocks 2' high.. but I have found that 95% of the work I do I need the axle hanging
Re: Car hoist?????
[Re: MR_P_BODY]
#1758988
02/21/15 01:36 AM
02/21/15 01:36 AM
Posts: 653 Fredericksburg Va
plycuda
Fredericksburg Va
well unlike most shops I don't do a few brake jobs a day. and I doubt they work on many if any race cars. so I guess it's what you would use it more for.
Re: Car hoist?????
[Re: 72chrgrally]
#1758990
02/21/15 01:10 PM
02/21/15 01:10 PM
MattW
Ontario Canada
It seems you and I are in the same boat, I'm planning a 24x36 build this year as well. I have an 11k John Beam hoist that I took out of my old shop, asymmetrical is the way to go for working on cars and light trucks. For a deal on a hoist get in touch with a tool dealer (Matco/Mac/Snap-on) and see what they have to offer. The tool manufactures have trade shows for the dealers this time of year and usually have a special on hoists. Where are you in Ontario Matt?
Steve
Ottawa. Not totally against the 4 post. pro Easier to get in and out of car. Do not have to perminatly mount it to floor. Movable. only need 4" of concrete. cons take up more room price limited access to suspension. Which way to go?
