1967 GTX cat whiskers? Who sells the correct ones?? #1758356
02/19/15 04:57 AM
02/19/15 04:57 AM
Victoria BC Canada
1967JimmyC Offline OP
Victoria BC Canada
Has anyone replaced the cat whiskers on a 1967 GTX. I am looking for the correct cat whiskers for this car. The cat whiskers that attach to the rear inside interior metal panels attach with a staple type fastener rather than a clip type fastener that is used on the doors and outside body. I am looking for the correct cat whiskers for the 67 GTX. Anyone out there have a solution for this problem? Anyone selling the correct cat whiskers? Thanks Jim
Re: 1967 GTX cat whiskers? Who sells the correct ones?? [Re: 1967JimmyC] #1758357
02/19/15 11:23 AM
02/19/15 11:23 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
AFAIK while there are some decent ones that work, there are none that are exact to originals.
Re: 1967 GTX cat whiskers? Who sells the correct ones?? [Re: 1967JimmyC] #1758358
02/19/15 01:12 PM
02/19/15 01:12 PM
Ontario,Canada
1967GTX440 Offline
1967GTX440  Offline
Ontario,Canada
Hi I am not home so I cannot give you part #. I bought a complete set cat paw for my 1967 GTX a couple years ago inside and outside of the windows. They had NOS & after market after market were a little bit more flimsy than the NOS . I got them here it's worth a phone call.
NOS REPRODUCTIONS
4-22425 Jefferies Rd.
rr#5 Komoka Ont NoL 1RO
519-471-2740
1-800-667-6200
www.nosreproductions.com
info@nosreproductions.com
Re: 1967 GTX cat whiskers? Who sells the correct ones?? [Re: 1967GTX440] #1758359
02/19/15 06:14 PM
02/19/15 06:14 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
I have no personal knowledge if the have clips or not but might be worth it to call - http://www.restorationspecialties.com/Products.html
and if they are the right ones then Dixie Restoration can get them for you
Re: 1967 GTX cat whiskers? Who sells the correct ones?? [Re: mikemee1331] #1758360
02/20/15 06:11 PM
02/20/15 06:11 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
I used Top Cat, bought from Dante's. They look nice but they squeeze the glass so tight I can barely roll the windows up or down.
I clamped the rear inner cats whisker in place and drilled tiny holes through both to allow the "staples" to go through the steel. I forget, I may have used TIG rod instead of the provided staples.
