Passenger door exterior mirror location.
#1757859
02/18/15 05:46 PM
02/18/15 05:46 PM
Posts: 56 Surrey, British Columbia
TseTse Runner
My '69 RR (pillar coupe)had a non-stock exterior mirror mounted on the passenger door. I am currently working on the major bodywork section of the restoration and need to know if the current screw holes are in the right location. My intention is to replace the mirror that the car came with with a correct / stock mirror. What are the measurements for locating the mirror in the correct location? Thanks. TseTse Runner.
Re: Passenger door exterior mirror location.
[Re: 70Duster440]
#1757863
02/18/15 09:19 PM
02/18/15 09:19 PM
Posts: 263 Spokane Valley WA
dan6412
Spokane Valley WA
Just my  my 70 Charger has a factory mounted passenger mirror and it is truly useless for backing up and/or seeing in traffic. If you still want to mount one I can messure it tonight for you. Dan
[Re: dan6412]
#1757864
02/19/15 03:29 AM
02/19/15 03:29 AM
TseTse Runner
Thanks for your input however it seems it is almost personal choice. Copy the location from the driver's door or locate it so it is useful. For my  the mirror is there to be used not just a piece of scenery. TseTse Runner
[Re: Andrewh]
#1757866
02/19/15 09:41 AM
02/19/15 09:41 AM
Posts: 7,258 s.w.fl
bonefish
s.w.fl
if you mirror the driver side, you will find the mirror is useless in that position. Cannot be seen by the driver.
however, I don't have any references to say where it should go, only that I recall it can't and wasn't placed like that.
that's what I did with mine.USELESS!
[Re: bonefish]
#1757867
02/19/15 10:16 AM
02/19/15 10:16 AM
Posts: 532 Marion, Ohio USA
kab69440
Marion, Ohio USA
I mirrored the driver's door location on my 69 Charger. The mirror works just fine and dandy there. I also have the seat at the farthest rearward lock. If you are an average sized person, you might want to mount it a few inches closer to the front of the door.
Just because you're paranoid, it doesn't mean they are not out to get you.
WANT TO BUY- Looking for a CD by 'The Sub-Mersians' entitled "Raw Love Songs From my Garage To Your Bedroom". Also, any of the various surf-revival compilation albums this band has contributed to.
[Re: mopar346]
#1757870
02/23/15 05:15 PM
02/23/15 05:15 PM
Posts: 6,515 Santa Cruz, California
Lefty
Hang tight for a bit, someone will post the engineering diagram bfore the day is out or at the very least accurate measurements of stock location. For some reason I am think it should have had a re-enforcemnt piece inside the door but only if it was a factory passenger side mirror car.
That would be interesting as my experience is like the others. Mirror image the driver door and the passenger side mirror is useless.
