Re: Mini Starter Lug Hits Block
[Re: bonefish]
#1755496
02/16/15 02:03 AM
02/16/15 02:03 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I'll give it a try. I might coat the connector and bolt with plasti Dip if I can mount the cable before I get it in place. Tight squeeze between the headers.
I’m listening.
[Re: Big Bad Bee]
#1755498
02/16/15 12:43 PM
02/16/15 12:43 PM
Posts: 289 Lowes
steve660
Lowes
Just cut down the lug. Also use a thinner nut, no washers and maybe sand/narrow the round end of the battery cable.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: steve660]
#1755499
02/16/15 01:35 PM
02/16/15 01:35 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
that's another thing I did used a narrower nut and replace the cable end with a copper one ,they are much tinner than the stock one you have.you can aklso just grind down a nut to make it tinner,just make sure you face the unground side down.I HEAR YA ABOUT THE HEADERS.
[Re: Moparnut426]
#1755505
02/16/15 08:25 PM
02/16/15 08:25 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
Mine was out of a 94 ram 2wd 1/2 ton 3.9 v6. I didnt have to cut it.
67' charger 499 RB
10.57 at 127
[Re: dartman366]
#1755506
02/16/15 08:34 PM
02/16/15 08:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
There is a different one that has the lug in a different spot a little further away from the block, run into that with the 440 in my old motorhome took it back to the parts house and swapped it for a different year if I remember correct and it worked just fine.
I think the issue here is that the OP is playing with a BB and yes I had a clearance issue when I was building mine... no problem on any SB
[Re: 1967dartgt]
#1755511
02/16/15 10:15 PM
02/16/15 10:15 PM
Posts: 289 Lowes
steve660
Lowes
Heres a picture of what cable looks like after I sanded/rounded end of cable. Also starter with shortened lug. The lug is offset but you can do same with any of them.
