Re: The Quest Has Begun......605 Hemi Build, Updated!
[Re: Dragula]
#2563777
10/14/18 10:41 AM
10/14/18 10:41 AM
Posts: 622 ct
jkgtx
ct
well interesting post as i was the one to purchase this repaired block not knowing it had a hot oil pressure problem,but all is good as it was used and what i was looking for,so after reading i went out and spent some time on the block,,plugged all mains oil passages ,blocked off head feeds,capped off all external places put in a used cam and pressure tested system,as dragula told me has good cam bearings well little soap and water shows i have a problem with rear cam bearing ,removed rear plug and put cam in back side has double the clearance as front bearing, is this the possible issue i would hope as i will rebearing cam and put together a 572 this winter after doing for checking into the block. i hope all works out and am happy to have a long awaited hemi block
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
[Re: jkgtx]
#2563780
10/14/18 11:02 AM
10/14/18 11:02 AM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Goodluck with that block as there have been plenty of posts on that one about lots of issues. Someone was missing something
[Re: jkgtx]
#2563803
10/14/18 12:07 PM
10/14/18 12:07 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
well interesting post as i was the one to purchase this repaired block not knowing it had a hot oil pressure problem,but all is good as it was used and what i was looking for,so after reading i went out and spent some time on the block,,plugged all mains oil passages ,blocked off head feeds,capped off all external places put in a used cam and pressure tested system,as dragula told me has good cam bearings well little soap and water shows i have a problem with rear cam bearing ,removed rear plug and put cam in back side has double the clearance as front bearing, is this the possible issue i would hope as i will rebearing cam and put together a 572 this winter after doing for checking into the block. i hope all works out and am happy to have a long awaited hemi block The cam bearing is interesting... I had a number of shops look at it, and none of them found any issues with the block itself, but they did find issues with our oiling system. We suspected this is why we lost a rod in the first place and repaired said oiling issues. But, time and time again, it was checked and nothing in the block was found, yet we still lost pressure only when hot. After months of getting no where, I finally decided to go and just buy another block and see....We put all the same parts in that block, including our oiling system, and no issues other than my carb went a lot leaner with this one. It sounds like you found more than we did. I paid a lot of money to different shops to look at it. Not to mention my time putting it in and taking it out of the car probably 10 times. I really wanted to believe we had a bad oiling system or somthing not related to the block, but if you found somthing, that's a good thing...We never found it.
[Re: jkgtx]
#2563819
10/14/18 12:51 PM
10/14/18 12:51 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
well interesting post as i was the one to purchase this repaired block not knowing it had a hot oil pressure problem,but all is good as it was used and what i was looking for,so after reading i went out and spent some time on the block,,plugged all mains oil passages ,blocked off head feeds,capped off all external places put in a used cam and pressure tested system,as dragula told me has good cam bearings well little soap and water shows i have a problem with rear cam bearing ,removed rear plug and put cam in back side has double the clearance as front bearing, is this the possible issue i would hope as i will rebearing cam and put together a 572 this winter after doing for checking into the block. i hope all works out and am happy to have a long awaited hemi block I have seen production blocks have weird oiling problems with worn out cam bearings. Jeep 4.0 inline 6 cylinder engines are notorious for loosing oil pressure due to cam bearing wear. You might be on to something.
[Re: jkgtx]
#2655194
05/13/19 10:51 PM
05/13/19 10:51 PM
Dragula
Randy i don't know when the cam bearings were replaced,as they don't look appearance wise to be bad but for sure the rear is excessive for clearance will check each one before i remove to see how they are,i will keep things posted if i find anymore Bearings were in the block when I got it. Hopefully you got it. As for an update, I haven't done a lot since last year, but it will get some track time this year. Spent the summer tuning the carb, and its a lot closer, but its still not EFI. When I get back to work, I am considering going to a 4500 Sniper for better cold starts and control..I also need to get an intake that gets me enough room to run an air cleaner. So I have the tallest Indy intake they make, but I will switching later this year because I can't fit my air cleaner, so I am open to suggestions. I would like to loose as little horsepower as possible. I have looked at the Eddy dual 4150 intake and the lower Indy 4500 as well as the Indy Arlene intake I am open to some feedback on who has tested what. Either way I figured i would show off the recently painted valve covers. Super tired of the polished valve covers, so I painted them...
[Re: Dragula]
#2655253
05/14/19 08:27 AM
05/14/19 08:27 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
I like the painted covers better...looks nice! How much room do you need for an air cleaner? FWIW, I can't fit an air cleaner on mine now either w/ the Indy 426-4 manifold and a 5" cowl. The Indy 426-3 will hurt power substantially. The Barton is your next best single 4500, but it may not give you enough clearance. It's roughly 11/16" shorter when measured sitting flat on a table. Barton is 7 and 9/16" tall, Indy 426-4 is 8.25". The Barton manifold is 10 lbs. heavier too. If you decide to go w/ two carbs, I'd use the Stage V manifold.
[Re: RustyM]
#2656072
05/16/19 05:46 PM
05/16/19 05:46 PM
Dragula
beautiful!
Where did you get the thermostat cover and and ridged radiator "hose"? Ok, so the thermostat housing is from Meziere....The chrome tubing, I have to confess, is from the local hardware store....Its a 20" undersink J-bend in 1.5".....lol. I like it for two reasons. It flows good and looks good, but also dissipates heat pretty well....
[Re: RustyM]
#2656347
05/17/19 05:43 PM
05/17/19 05:43 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
thank you as i'm having radiator plumbing issues with top hose on big block duster and- i just don't want ugly. I can’t believe that guys will spend 1000’s or dollars on some items but still run 50 years old flex line technology for radiator lines. Step up to the 21 century and change over to AN lines and Fittings. Come on in, the waters great.
[Re: Dragula]
#2656526
05/18/19 10:41 AM
05/18/19 10:41 AM
Posts: 19,310 north of coder
moparx
beautiful!
Where did you get the thermostat cover and and ridged radiator "hose"? Ok, so the thermostat housing is from Meziere....The chrome tubing, I have to confess, is from the local hardware store....Its a 20" undersink J-bend in 1.5".....lol. I like it for two reasons. It flows good and looks good, but also dissipates heat pretty well.... would a black painted piece of tubing dissipate heat as well [or close to] as the chrome piece ? i'm not a "shiny" guy. pittsburgh, an fittings are good, but see above.
[Re: RustyM]
#2657516
05/21/19 11:38 AM
05/21/19 11:38 AM
Dragula
1'm having the dickens making the an fittings work for me due to traveling a short distance with two turns. Yeah, you have to have some length between fittings...... Just had it out for a cruise today, and she is running really good. I made a couple minor carb changes, and it seemed to like it. Still a tad lean at cruise, but not bad....we will see when the hotter weather gets here.
[Re: Dragula]
#2657560
05/21/19 12:55 PM
05/21/19 12:55 PM
Posts: 43,099 Bend,OR USA
Cab_Burge
What AFR is a "tad lean"? I like at or above 14.8 AFR at light part throttle cruise in high gear below 2200 RPM on 91 octane pump swill
[Re: Cab_Burge]
#2657593
05/21/19 02:48 PM
05/21/19 02:48 PM
Dragula
What AFR is a "tad lean"? I like at or above 14.8 AFR at light part throttle cruise in high gear below 2200 RPM on 91 octane pump swill Right around 14.5-14.8.....somtimes it will go to 15.0 which I really don't like. Doesn't seem to bother it, but I do not want to burn anything up. Most of the time she is closer to 14.0....This is why I like efi...Set the AFR and forget about it...
