Adding Air Conditioner to a Trailer?? #1753751
02/13/15 04:26 PM
02/13/15 04:26 PM
HR3128 Offline OP
HR3128  Offline OP
How big a deal is it to add a roof mounted air conditioner to an enclosed trailer? I have been looking for a trailer with air but that limits the choices. Anyone done this before?
Re: Adding Air Conditioner to a Trailer?? [Re: HR3128] #1753752
02/13/15 04:33 PM
02/13/15 04:33 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
If the trailer is prepped meaning the roof is reinforced and the wiring is up there its a piece of cake. If it is not prepped and the interior is finished it is tough. Look for a trailer that is prepped and it is almost plug and play.
Re: Adding Air Conditioner to a Trailer?? [Re: HR3128] #1753753
02/13/15 05:03 PM
02/13/15 05:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I replaced my AC unit 2 years ago.. it does need the
reinforcement around the unit and the power up to it..
the switch on both of mine was built into the AC unit
so it just needed the 120v... also I dont know if
you sleep in your trailer but IF you do put in the
AC look at the ones with the heater built in.. if you
are in any northern areas
Re: Adding Air Conditioner to a Trailer?? [Re: HR3128] #1753754
02/13/15 05:12 PM
02/13/15 05:12 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I know it might be a little "Larry the Cable Guy" but, I've been thinking of doing something like this with mine. Window AC units are way cheaper and I believe take less power to run than rv units
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Adding Air Conditioner to a Trailer?? [Re: MoParFish] #1753755
02/13/15 06:56 PM
02/13/15 06:56 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
that would look much better mounted inside in a fabbed box with a grill on the outside,plus nobody could steal it...
SFI 25.5 depends,no leak,even at 213 mph....
Re: Adding Air Conditioner to a Trailer?? [Re: dakotawilly] #1753756
02/13/15 09:37 PM
02/13/15 09:37 PM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
Like previous mentioned if prewired and braced it is easy to do and link below is the best price I found when I bought mine.
http://www.adventurerv.net/major-appliances-air-conditioners-c-24_40.html
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Adding Air Conditioner to a Trailer?? [Re: 65 Hemi] #1753757
02/14/15 12:40 AM
02/14/15 12:40 AM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
I just bought two Coleman Mach 3 13,500btu units from a guy in KY. He was cheaper than anywhere I found on line if you interested in his number, pm me and I will get it for you.
Re: Adding Air Conditioner to a Trailer?? [Re: Joes66dart] #1753758
02/14/15 12:56 AM
02/14/15 12:56 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
If the trailer isn't insulated, tough for a ac unit to keep up when its really hot out
