I wanted my system to be all off-the-shelf from a local parts store, so I went with a Ford Superduty truck filter will work nicely between the pump and the TBI. The Hastings number is
GF354 (
Rock Auto) It's 3/8" barbs and if you really work the hose on you can put a second clamp next to the body to keep the hose on. It's only about 14 PSI for the TBI system, so no high pressure issues.
Generic fuel lines in/out of the TBI can be purchsed and bent (Rock Auto is a LOT cheaper than the local stores...):
Dorman 800-170 is 16mm x 1.5 hard 3/8" line that is 4" long
Dorman 800-151 is 14mm x 1.5 hard 5/16" line that is 18" long
Dorman 800-153 is 16mm x 1.5 hard 3/8" line that is 18" long
Dorman 800-156 is 14mm x 1.5 hard 5/16" line that is 30" long
Dorman 800-157 is 16mm x 1.5 hard 3/8" line that is 30" long
-Ben
