E Body Parking Brake Handle Grommet #1752234
02/11/15 01:18 PM
02/11/15 01:18 PM
Land of 10,000 Lakes
44D6PAKCUDA Online content OP
44D6PAKCUDA  Online Content OP
Does anyone sell the hard plastic grommet that goes around the park brake release handle on E Bodies? I saw a guy selling them a while back on eBay but don't see them now.I think '70 was a clear/white grommet and '71 was black or at least that what he was pitching.The one in my '70 handle assy is clear/white and broken.Thanks for any help
Re: E Body Parking Brake Handle Grommet [Re: 44D6PAKCUDA] #1752235
02/11/15 02:57 PM
02/11/15 02:57 PM
Portland, OR
shawge Offline
shawge  Offline
Portland, OR
Not sure if they are being reproduced. The one on my 70 was black. I've read (from Alan Gallant?) and tried cutting off the end of a plastic insulation pad nail. Works great!
edit: spelling
Re: E Body Parking Brake Handle Grommet [Re: 44D6PAKCUDA] #1752236
02/11/15 05:55 PM
02/11/15 05:55 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Not that I am aware of.
Atha auto fasteners has one but it's C body only (I have them here somewhere)
Re: E Body Parking Brake Handle Grommet [Re: gtx6970] #1752237
02/12/15 01:55 AM
02/12/15 01:55 AM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
It seems a piece like that could be turned down on a lathe using a piece of Delrin. Do you know anyone with a machine shop?
I also wish someone was reproducing the bumper. It is similar to the one for the clutch pedal but the pad is thicker.
Re: E Body Parking Brake Handle Grommet [Re: 44D6PAKCUDA] #1752238
02/12/15 05:09 PM
02/12/15 05:09 PM
NC
1970A66 Offline
1970A66  Offline
NC
I put a regular rubber grommet in the bracket hole along with a flat washer between it and the spring.
I just checked it and it is good after 3 years now.
Re: E Body Parking Brake Handle Grommet [Re: 1970A66] #1752239
02/12/15 08:26 PM
02/12/15 08:26 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I'm pretty sure I have pictures I can post when I get home
Re: E Body Parking Brake Handle Grommet [Re: AAR#2] #1752240
02/13/15 01:08 AM
02/13/15 01:08 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
OK found the pic, thought I tossed it for a minute. Basically I went to the local Ace Hardware and bought a nylon bolt large enough to cut the bushing out of it. Dial calipers and a table top lathe were my friends that allowed me to make the bushing. Turned out great, look and fit.
Upper Left - Start Bolt (I bought an extra in case I screwed up the first one)
Bottom Left - Original part
Upper Right - Shank of bolt that was clamped into the lathe, the drop left over
Bottom Right - Fabricated bushing cut from the head of the bolt and a portion of the shank
Re: E Body Parking Brake Handle Grommet [Re: AAR#2] #1752241
02/14/15 04:16 PM
02/14/15 04:16 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Yep, they dont too hard to make, If some one could provide me with a example , I could make them one for free, Then make 50 or so extra for everyone else
Re: E Body Parking Brake Handle Grommet [Re: 44D6PAKCUDA] #2077216
05/20/16 05:39 PM
05/20/16 05:39 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Making them from nylon bolts would be expensive (Relatively speaking). Call up a plastics supplier and buy a foot of nylon rod.
