Re: 5.7 Hemi in a 67 Barracuda
[Re: Daty Rogers]
#17527
01/05/06 02:29 PM
01/05/06 02:29 PM
Posts: 1,106 michigan
440whiteboy
michigan
its good to see you making more progress daty. when you get the oil filter assembled can you post a pic for reference.
my updates...
finally got the trans in and the hump is attached. Im waiting for another hose from keisler before I can fill with oil and bleed the line. got my pistol grip handle back with the letters TKO stamped in. my dana rear end should be here in a few days I had ordered from Dr. Diff. then I can finish my brake lines. taking my aluminum radiator I ordered from don @ FBO to the shop to get the brackets stitched welded. still need to prefit my headers.
They only see Stars... when hit by a Mopar!
[Re: 68440fish]
#17530
01/06/06 01:56 PM
01/06/06 01:56 PM
440whiteboy
michigan
68440Fish just saw your link to CM filters site.
good design on the canisters and filter kits.
*found out last night that the radiator I have was shipped from another vehicle. will have to go thur the 'Redo' process again. another iron in the pot. sure is a good thing I made a phone call to double check it. I had an appointment with the welder to stitch on the brackets and when I went to do my layout I thought something didn't look right with the inlets in the wrong place. when I had placed the order we repeated the locations three times? somehow it got mixed up.
the one good thing its from the good ole USA and I got a 'Yup, Dah your right, its our fault' and we will take car of it Gus!
[Re: Daty Rogers]
#17531
01/07/06 12:23 AM
01/07/06 12:23 AM
Posts: 151 Plano, TX
68440fish
Plano, TX
Are you getting crimped braided hoses or the ones with the "re-useable" fittings?
Michael
Plano, TX
68 Barracuda Notch Pro Patina
[Re: Daty Rogers]
#17537
01/11/06 04:47 PM
01/11/06 04:47 PM
68440fish
Plano, TX
Yikes, that's tight. At least the input is visible. Can the collar be clearanced to clear?
[Re: bacaruda]
#17540
01/22/06 06:34 AM
01/22/06 06:34 AM
Posts: 4,442 Texas
Daty Rogers
World's Greatest Husband. I love you Robyn
Texas
And more powerful too!!! For even more power (and disable the 5700rpm hard limit) Ben Grasso at www.pfcenterprises.com has an ecm and a feedback system that uses wide loop O2 sensors for true control on the efi. As it is stock the crate motor has no O2 sensor feedback. I got some stuff done so far, I found a 727 inspection plate but had to cut it square to fit around the motor, everything is buttoned up now. The plate and starter have to be in place before the headers swing into place. Last week I slept the entire weekend, didn't get a thing done on the vert... -Daty
[Re: Daty Rogers]
#17541
01/23/06 05:52 PM
01/23/06 05:52 PM
440whiteboy
michigan
just saw your post and noticed you said you had to put the starter in first? on my E body, I had to install the header first then the starter, after a couple of trail fits I needed to ding my headers too. removed the power steering gear box which would not fit afterwards. went with a manaul gear box - was hammer tight up against the shock tower two hits and she was in. stubborn I was without jacking up the motor... didnt want the extra work that night, my excuse to switch. planning on picking up my dana this week. radiator is here and is missing the brackets.
[Re: Daty Rogers]
#17543
01/24/06 11:39 AM
01/24/06 11:39 AM
440whiteboy
michigan
so R U getting closer to making your deadline?
[Re: Daty Rogers]
#17544
01/24/06 11:44 AM
01/24/06 11:44 AM
440whiteboy
michigan
Forgot to say........ I could have left the header hanging and did the starter @ the same time too. my thought was for future repairs without dropping the header and installing a new gasket for a possible starter change-out.
