Re: town wagon project
[Re: dogdays]
#1749937
02/27/15 03:41 PM
02/27/15 03:41 PM
Posts: 93 mesa , az
penski61
mesa , az
lol not sure the paint scheme yet but doubt it will be green these are crown vic wheels , i didn't think they were bad ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/dodge7_zpscdb3bf73.jpg) however the crown vic is the same width as old suspension so i just need some wheels with about 4.5" backspace as far as being level for the frame it needs to be pretty close but the biggest thing is to make sure you can get the caster to about 6.5" degrees which is done by the trailing arm
[Re: penski61]
#1749946
03/03/15 12:39 AM
03/03/15 12:39 AM
Posts: 16,841 Between Houston & Galveston TX
SattyNoCar
Why not go fuel injected (either stock or after market)? ![](/ubbthreads/images/graemlins/shruggy.gif) From what I've read, an in tank pump would probably be best, quieter, runs cooler. Today's gas boils when too close to a hot cup of coffee. Given your location, I'd be doing all I can to prevent heat in the fuel system. Just my ![](/ubbthreads/images/graemlins/Twocents.gif) to give this a ![](/ubbthreads/images/graemlins/bump.gif) Love the build! Wish I had the skills to something similar. ![](/ubbthreads/images/graemlins/beer.gif)
John
[Re: Golden-Arm]
#1749948
03/03/15 01:15 AM
03/03/15 01:15 AM
Posts: 93 mesa , az
penski61
mesa , az
the tank i have does not have the ability to run an in tank pump and its really the only tank i found that works for the dodge short of buying an expensive custom made tank (not sure if cutting an in tank pump is an option). im leaning towards a mechanical fuel pump because of the simplicity and dont have to worry about overheating but an electric fuel pump would end up being cheaper i wanted to do a carb setup vs efi cause i have enough vehicles with computers and wanted something with bare bones electrical ![](/ubbthreads/images/graemlins/smile.gif) edit: i did find this http://www.tanksinc.com/index.cfm/page/ptype=article/article_ID=6/art6.htm
[Re: penski61]
#1749949
03/03/15 02:14 AM
03/03/15 02:14 AM
Posts: 10,640 Freeport IL USA
poorboy
Freeport IL USA
The magnum engines don't have provisions for mechanical pumps. Mopar went to electric pumps in 86 or 87, and motors made since about 1988 don't have provisions for mechanical pumps. It would be a major pita to adapt one in. I'd go for an electric pump at the tank if you can't put one inside the tank. The electric pumps are a little more noisy outside the tank, but its easy to get used to. The start problems electric pumps solve is worth any noise they may make.
I haven't run a mechanical pump on anything for 15 years or more. In all that time, I had 1 electric pump fail when I got into crappy gas once. For several years after that, I carried a spare electric pump. The only times I used the spares was when someone we were traveling with had mechanical pumps fail. Gene
