65 town wagon project
#1749913
02/09/15 02:31 AM
02/09/15 02:31 AM
Posts: 93 mesa , az
penski61
mesa , az
started a build on a 65 town wagon , picked it up a few months ago . when i bought it i was told it would take a few hours and the wagon would be back up and running just needed a starter and alt , well after i got it home that was not the case . i had to go thru all the hack wiring just to get it to where i could even try and start it , finally got that done and the engine would not turn over ( i tried by hand first but only moved it 1/4 turn ) took the new starter out and tested and was good . pulled the valve cover off (slant 6 ) and found cover was not sealed and water was all over the rocker and springs , so i pulled the head and checked the block and found the engine would turn over now but the first piston had bad rings so i decided to just pull the engine and do a v8 swap . while i had the front end apart and engine out i decided to modify the frame to accept a crown vic front suspension that uses the aluminum cross member will all the suspension tied onto it , Im almost done with the install just need to tie in the trailing arms that come off the lower control arm . Yesterday i went to the Jy and pulled a 5.9 magnum and got it mocked up then one of the motor mount brackets just about done , hoping to finish it off get the 2nd one done , pull motor back out , box in the lower portion of the brackets then finish off the trailing arms day we picked it up ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/dodge_zpsba92fb7d.jpg) out with the old ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/dodge2_zps79ea32fd.jpg) old motor mounts out and frame pressure washed ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/dodge3_zps92d7d4c6.jpg) boxing started ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/dodge4_zps9dcdb55f.jpg) frame cleaned up ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/dodge5_zps86c93fd8.jpg) suspension installed ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/dodge6_zps330a1510.jpg) ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/IMG_20150101_130821956_zps61fe0002-1.jpg) ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/IMG_20150101_130957_zps356b85d3-1.jpg) and how it currently sits ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/dodge7_zpscdb3bf73.jpg) went to the junkyard and pulled a 46rh /a518 out of a 1990 d150 , got it all cleaned up and bolted to the engine . put both back in the wagon and found i had to cut out the old trans cross member so the new trans could sit in down, once i had that cut out the other cross member was right under the very tail end of the trans so i decided to make a new removable cross member . ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/trans_zps8b08c737.jpg) ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/IMG_20150110_165028332_zps2b94eff1.jpg) ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/IMG_20150110_165033708_zpsb3c1bc92.jpg) ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/IMG_20150110_170239033_zps603a93c7.jpg) ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/IMG_20150110_170222048_zps3feb2201.jpg) started on the 4 link in the rear , so far i got a section of the frame plated and upper link mounts done on both frame and axle . also went to the junk yard and found a rear sway bar off a crown vic that fits very well , just had to make the axle mounts ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/IMG_20150118_190256799_zpsf508096b.jpg) ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/IMG_20150118_183245022_zpsdd1a3181.jpg) ![](http://i190.photobucket.com/albums/z219/penski61/town%20wagon%20project/IMG_20150118_183225275_zps5fa5168f.jpg)
Re: town wagon project
[Re: stumpy]
#1749917
02/09/15 03:34 PM
02/09/15 03:34 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Looks good so far but you deleted the important part as to what it is and what you r plan is.
Wonder why he deleted it I saw it posted last night and it looked to be a great project. If I remember right it was a 1955 Town Panel wagon and I like the direction he is going ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RUNCHARGER]
#1749919
02/09/15 07:37 PM
02/09/15 07:37 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
Wow....I agree.....it looks like it's all Mopar too. I'm using those Grand Cherokee rear disk breaks also on my Valiant.
Moparlee
[Re: Robbins]
#1749921
02/15/15 05:15 PM
02/15/15 05:15 PM
Posts: 1,722 Chicagoland
Cooter
Chicagoland
Well, except for the Crown Vic front suspension. ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: Golden-Arm]
#1749925
02/16/15 04:00 AM
02/16/15 04:00 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
looks like a pretty cool build. what's up with your first post?
It wasn't much really, he just showed a white town wagon and how he tore it apart. Very strange that he would just delete the first post and disappear. Proprietary information? ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Robbins]
#1749927
02/26/15 02:46 AM
02/26/15 02:46 AM
Posts: 93 mesa , az
penski61
mesa , az
huh , i didn't realize the thread was still visible , most forums will delete the thread when ou delete the 1st post i was having issues with photobucket and was going to re-post once i got the issues fixed but forgot to update since ive been busy with the project
[Re: penski61]
#1749928
02/26/15 02:51 AM
02/26/15 02:51 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Understandable once you post more pics and give us some more info. ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: penski61]
#1749931
02/26/15 10:43 AM
02/26/15 10:43 AM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
Dog tested and approved. ![](/ubbthreads/images/graemlins/laugh2.gif) I like it better than a Subaru.
[Re: Guitar Jones]
#1749932
02/26/15 11:41 PM
02/26/15 11:41 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
![](/ubbthreads/images/graemlins/haha.gif) That's funny. I just saw that comercial for the first time about a minute ago. Can't wait to get home tommorow night so I can take a look at the photos. Glad this thread was updated. Seems to be a fun build.
I have mechanical Aptitude. I can screw up anything.
