Re: 5.7 Hemi in a 67 Barracuda
[Re: Daty Rogers]
#17449
10/29/05 12:38 PM
10/29/05 12:38 PM
Posts: 1,106 michigan
440whiteboy
michigan
Only have this view to show you. I pulled the motor out again. It was only a tempory check on fit and clearance's. I decided to go with TTI's complete E Body exhaust system. Went to Mancini's and picked up a set of ceramic coated headers and placed the order that comes with their set of recommended motor mounts with the shumaker set and the block off plate. So will have to go with the inner fender by pass oil filter mount. Was going with the 4 x4 truck oil filter offset, and S & P motor mounts which are on in this pic. the offset is waiting for me @ the dealer to pick up which I no longer need. With the S & P mounts the oil filter would of hit and needed the offset.
They only see Stars... when hit by a Mopar!
[Re: Daty Rogers]
#17454
11/05/05 10:47 AM
11/05/05 10:47 AM
Posts: 4,442 Texas
Daty Rogers
World's Greatest Husband. I love you Robyn
Texas
[Re: Daty Rogers]
#17457
11/08/05 09:39 AM
11/08/05 09:39 AM
440whiteboy
michigan
hey daty Im glad you posted in with your updates -- just got my exhaust from TTI yesterday. in opening up the box, just like you -- No block off plate! will have to make the call. also noticed in reading the install sheet that they recommend for dual exhaust metal body hanger brackets --- since I had ordered a complete exhaust system dont you think that would have been included or at least mentioned with the order sheet? another thing is with the box of headers I have a set of collector tubes, in the exhaust box I have another set of collector tubes? doesnt make since to pay for the same parts twice in having doubles? maybe I can use them as stacks in my hood? havent heard from don yet as to the delivery on my package. front end parts R & R all done. looking for a spanner wrench to pull the fan. the new mounts look smaller and offset compared to S & P 's set which I need to change them out yet. still no progess on the trans other than pulling it all out of the boxes.
