Install freeze plug in 2002 Dodge Ram with 360 magnum..
#1744795
02/02/15 04:35 AM
02/02/15 04:35 AM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
A have a leaking freeze plug in my 2002 Dodge Ram with 360 magnum. And of course the freeze plug that is leaking is the one located on the passenger side behind the engine mount! What is the easiest way to get at this freeze plug and remove it? What is the best way to knock the old one out and put the new one in? Should I try to support the engine on the passenger side while removing the engine mount to gain access to the freeze plug?
Re: Install freeze plug in 2002 Dodge Ram with 360 magnum..
[Re: Blakcharger440]
#1744796
02/03/15 12:33 AM
02/03/15 12:33 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
If it were mine, I'd pull the engine and replace them all at once.
As long as your exhaust isn't rusted solid, you should be able to pull the whole motor in about 3 hours, figure an hour to do the plugs, and another 3-4 hours to reinstall everything.
If you've never done any heavy maintenance in the engine bay, then double the time estimate as you'll be fighting sized up bolts and stuff. Regardless, you'll be able to start on a Saturday morning and finish it by Sunday afternoon, and they'll all be fresh leak free plugs.
**Photobucket sucks**
[Re: 70Cuda383]
#1744797
02/03/15 04:35 AM
02/03/15 04:35 AM
Blakcharger440
Wichita,KS
Unfortunately no can do. This is my daily driver and I will not have anybody else helping me and would need to get it back on the road in short order.
#1744798
02/03/15 07:43 AM
02/03/15 07:43 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
If its behind the engine mount, I would get a bolt in plug. Trying to tap one in under the truck without a a straight shot is difficult if there is clearance to get this one in it will save alot of time.
Ive used these several times without issue.
#1744799
02/03/15 10:42 AM
02/03/15 10:42 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I have not tried it on a 360 V8 but draining the coolant from the block and holding small pieces of Dry Ice against a freeze plug to deeply chill it has worked for me in the past. If you can borrow one or a pair of those magnetically attached electric oil pan heaters and place it on the block as near as possible to the freeze plug hole, that will help too. Chill the new freeze plug and it will go in easier. Any left over dry ice can freeze off warts and moles.
[Re: Supercuda]
#1744801
02/04/15 10:14 PM
02/04/15 10:14 PM
70Cuda383
Marysville, O-H-I-O
daily driver I get, but can you afford a weekend with it down? or 2 days if you work weekends.
don't need a helper. these engines are as simple as an engine an old muscle car engine, they just have a few more wires and sensors in the intake manifold/Throttle body due to the EFI, but the rest is NEARLY identical to a 1970s 360
by myself, I can have the motor out of my Dakota in about 3 1/2 hours--but I realize that's not fair because I've had it in and out before, so I have practice, and a very clean engine bay due to a stripped out model from the factory (no AC, Cruise, etc)
