Body drain plugs #1744591
02/01/15 10:39 PM
02/01/15 10:39 PM
central IL reg Nov 18, 1999
Stroker Offline OP
Stroker  Offline OP
Does anybody sell a correct floor/trunk drain plug?
I could've sworn they were rubber, not plastic.
Some may have been, but not all.
(72 B body)
Re: Body drain plugs [Re: Stroker] #1744592
02/02/15 10:49 PM
02/02/15 10:49 PM
Minn
SportF Offline
SportF  Offline
Minn
The early cars, 62-65 are plastic in the floor, with a few odd ones which are rubber, usually small ones. I bet the same goes for the newer ones like yours.
Re: Body drain plugs [Re: SportF] #1744593
02/03/15 07:50 AM
02/03/15 07:50 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Yep mostly plastic. Check the local wrecking yard and get some from a b van. Heck I bought a lizzard cage a couple years ago with a plastic plug in it. The plug was stamped CAPPLUGS and had the DPCPD logo too.
