Re: 5.7 Hemi in a 67 Barracuda
[Re: 57HemiDart]
#17397
10/16/05 02:15 AM
10/16/05 02:15 AM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
Hi guys, jumpin' in if I may. I was planning on using an Alterkation crossmember to eliminate any steering linkage/ oil pan/ header clearence issues invovled with the swap in a b body. Any thoughts on this?
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: 5wndwcpe]
#17398
10/16/05 03:09 AM
10/16/05 03:09 AM
Posts: 4,442 Texas
Daty Rogers
World's Greatest Husband. I love you Robyn
Texas
http://www.hawayaracing.com/barracuda.htm has done one with an altercation style setup. I've sent him a few email asking about stuff and he replied with one-liners (no help to me though). I REALLY want to make mine work with a stock (well for me) kframe/suspension. My biggest issue has not been with the mounts or headers or tranny but with the serpentine belt, it's killin me... -Daty
[Re: 57HemiDart]
#17403
10/17/05 11:53 PM
10/17/05 11:53 PM
Posts: 1,106 michigan
440whiteboy
michigan
I've been in contact with Don about the fuel system. I had asked him to order a complete 'user friendly' kit for my E body. He claims they have all the bugs worked out. I have also talked to S & P about the system they have used on the challenger project last year. Again they claim the route they had used works good also. I'm leaning with FBO because of the modified stock tank idea. He says that the pump on the rail does not heat up and also is quiet.
They only see Stars... when hit by a Mopar!
[Re: Daty Rogers]
#17406
10/18/05 10:22 AM
10/18/05 10:22 AM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
Daty, You can bump the belt length a couple inches one way or the other by changing pulley sizes or running the belt outside or inside the tensioner (if possible). I was able to find a belt for my Mag serpentine swap by changing my tensioner to run on the inside of the belt rather than the outside. This took a pulley swap from a Jeep I-6 I grabbed from the salvage yard. Here's the Gate's on-line belt catalog for micro-V belts. You'll have to go to the end of the catalog to find 7-rib belts. PN's will start with K07xxxx (K=micro-V, 07= # of ribs, xxxx= length in mm). Clair
