Re: Demon trunk lock - Please help [Re: DusterJeff] #1741101
01/29/15 05:17 PM
01/29/15 05:17 PM
Export, PA
jayyohe Offline OP
jayyohe  Offline OP
Export, PA
Did you try squirting some WD-40 in the lock and gently wiggling it with the key afterward??????
Have not tried this yet, but thanks for suggesting it.
jayyohe@yahoo.com Export, PA 1971 Dodge Demon - 440/4-Speed
Re: Demon trunk lock - Please help [Re: Rhinodart] #1741102
01/29/15 05:20 PM
01/29/15 05:20 PM
Export, PA
jayyohe Offline OP
jayyohe  Offline OP
Export, PA
The key should open the door and be used in the ignition, that would be a Pentastar style key. The key that opens the trunk is a round style key. Did you ever use the key that doesn't work in the lock before?
Both of my keys are the Pentastar type but the one used to open my trunk. I believe the previous owner had the lock rekeyed. I have tried both keys I have, the one that is thin and wore thin goes in the whole way and seems to fit good but won't turn. The second key I have won't even go in the whole way.
Re: Demon trunk lock - Please help [Re: jayyohe] #1741103
01/29/15 07:11 PM
01/29/15 07:11 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Try this, put the key in the lock, now rapidly pull & push the key as fast as you can. You only have to move it back & forth about 1/2". As you're doing this turn the key to see if it will open. Turn while you're doing the sliding in & out. I've opened some locks with a non matching key this way, worth a shot.
Re: Demon trunk lock - Please help [Re: GODSCOUNTRY340] #1741104
01/29/15 08:47 PM
01/29/15 08:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Before you butcher anything up or ruin your paint just drive it down to a locksmith and have him open it.
DO NOT use WD40 on the lock, there is a reason real lock lube isn't a liquid. If you feel the need to try something anyway go to Home Depot and buy lock lube, it's usually by the towing accessories.
Don't be the exception.
Re: Demon trunk lock - Please help [Re: Supercuda] #1741105
01/30/15 12:52 PM
01/30/15 12:52 PM
Export, PA
jayyohe Offline OP
jayyohe  Offline OP
Export, PA
UPDATE
Powdered graphite = FAIL
WD-40 = FAIL
Push, pull, wiggle wiggle, twist = FAIL
Lightly tapped with a screwdriver and hammer = FAIL
Flat screwdriver in the slot and turn = FAIL
3/8" drill bit through the tumbler = SWEET SUCCESS
I musta had 5 layers of masking tape around the lock and nothing was damaged. I got impatient and didn't wait to try and get a new key made. Now I need to install a new lock.
Guess I'll never really know what happened ---Oh well!!!
Thanks for all the great suggestions.
Re: Demon trunk lock - Please help [Re: jayyohe] #1741106
01/30/15 02:57 PM
01/30/15 02:57 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Sorry to hear that you had to drill out the lock but it's an easy replacement. Glad you were able to break in.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Demon trunk lock - Please help [Re: FJR doc] #1741107
01/31/15 12:34 PM
01/31/15 12:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Drilling works but they're easy to pick. I forgot the keys to my Road Runner once, 3 hours away at the drag strip. My son had the trunk open in 3 minutes. Had the steering key lock done almost as quick. Him and his brother used to try and open old file cabinets when they were kids and taught themselves to pick locks.
Doug
Re: Demon trunk lock - Please help [Re: jayyohe] #1741108
01/31/15 11:33 PM
01/31/15 11:33 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I haven't bought one in a few years, but you should be able to get a new trunk lock kit at NAPA. It come with the cylinder, 2 keys, and assorted levers that go from the lock cylinder to the latch mechanism.
