mopar 509 and 528 cam ???
#1741017
01/28/15 02:20 PM
01/28/15 02:20 PM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
hi any one here using the 284/528 ,or newer 509/114 cl, not the old 108 cl, cams in a 440 or larger heavy street car that sees track maybe 6 times a year? what is your idle vac reading in gear warm engine? idle speed ? what gear ratio ? thank you ! what weight of car? what et / mph at the track ? headers or manifolds ? stall speed ? thank you ! '
Re: mopar 509 and 528 cam ???
[Re: gss]
#1741020
01/28/15 10:29 PM
01/28/15 10:29 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Any idea when the .509 cam changed to the new specs?
Its been quite a few years back that the New LSSA was offered. The Old profile is still available, the New profile is just another option.
[Re: mosweethemi]
#1741022
01/29/15 08:51 AM
01/29/15 08:51 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I've run both in several 440 cars- The 528 is a better cam and a little more street friendly. Run with everything from 2.76 to 4.56 gears. The 509 always needed a loose converter and gear to run well and sooner or later would spear a factory stamped rocker from the required spring pressure.
No opinion on the "new" 509 as I have not run one of those.
"I think its got a hemi"
