Going to 15" ralleys soon on my Duster #1739889
01/27/15 02:53 AM
01/27/15 02:53 AM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
What, if any changes should I make to my speedo gear in the trans. to keep my speedo accurate?
Re: Going to 15" ralleys soon on my Duster [Re: bigblock340power] #1739890
01/27/15 05:54 AM
01/27/15 05:54 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Tires of a larger diameter will require a smaller speedometer pinion.
The larger tires spin fewer revolutions per mile. The smaller speedo pinion will make up for it.
My 27 1/2" tires result in a speedo tooth count very close to the differential ratio. 3.91 needs a 39 tooth. The 3.55s need a 34 or a 35 tooth.
Re: Going to 15" ralleys soon on my Duster [Re: Kern Dog] #1739891
01/27/15 10:20 AM
01/27/15 10:20 AM
Elk Grove, Calif.
Elk Grove, Calif.
I guess I should have put in the gear. 3.23 for the street. I know their is a chart somewhere. I'll have to look around.
