Page 2 of 3 1 2 3
Re: 518 to OD833 behind my BB 86 RC [Re: CTD5.9] #1889978
08/12/15 12:49 AM
08/12/15 12:49 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Originally Posted By rednuck
Originally Posted By savoy64
so did that 833 come off a chevy diesel truck?----i have never heard of one on a dodge unit as a 4x4 setup....
I downloaded the picture, looks like a car/2wd 833 to me
Correct........ more pictures this week as I get the column back together.....with new grant wood steering wheel to match the pistol grip shifter and Pentastar horn button.
Moparlee
Re: 518 to OD833 behind my BB 86 RC [Re: Robbins] #1890419
08/12/15 06:04 PM
08/12/15 06:04 PM
dogdays Offline
dogdays  Offline
The Chevy A-833ODs came with Chevy front ends on the transmission, would need an adapter to bolt into a Mopar.
R.
Re: 518 to OD833 behind my BB 86 RC [Re: Robbins] #1890605
08/12/15 10:39 PM
08/12/15 10:39 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the guy that told me about them said that some had the chevy bolt pattern and some had the dodge pattern---the bellhousing for the dodge one is pretty rare as chevy guys didnt know what they looking at...
Re: 518 to OD833 behind my BB 86 RC [Re: savoy64] #1891039
08/13/15 03:01 PM
08/13/15 03:01 PM
dogdays Offline
dogdays  Offline
Wow, never knew that! So bolting an A-833 behind your 350 is possible with factory parts.
Re: 518 to OD833 behind my BB 86 RC [Re: dogdays] #1891117
08/13/15 05:03 PM
08/13/15 05:03 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the 833 is a favorite with chevy guys running circle track---remember the 833 hemi is the strongest 4 spd ever and the regular 833 is the second strongest---the budget racers are always looking for them...
Re: 518 to OD833 behind my BB 86 RC [Re: savoy64] #1893317
08/17/15 12:07 AM
08/17/15 12:07 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
The column's done.
Moparlee
Re: 518 to OD833 behind my BB 86 RC [Re: Robbins] #1893321
08/17/15 12:09 AM
08/17/15 12:09 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Got the bell painted up.
Moparlee
Re: 518 to OD833 behind my BB 86 RC [Re: dogdays] #1898132
08/24/15 02:16 AM
08/24/15 02:16 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
----i found the thread on this gm bell housing----it is an 82-84 6.2 dual pattern #14061655----this makes it happen for the 833.....
Re: 518 to OD833 behind my BB 86 RC [Re: Robbins] #1898134
08/24/15 02:23 AM
08/24/15 02:23 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
and robbins limit your power displays to first and second gear---3rd and 4th are somewhat weak due to being reversed in order on the mainshaft----passon sells a hemi cut gearset for the 833od that is good to 750hp---one of my friends runs one at the dragstrip in a blown stroker 440 with no problems in 5 years---loves it as he can drive on the highway at fairly normal rpms.....
Re: 518 to OD833 behind my BB 86 RC [Re: Robbins] #1898444
08/24/15 04:40 PM
08/24/15 04:40 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Is that a BB bell housing made for the bigger bearing retainer on the OD trans or did you have to machine the bell housing?
Re: 518 to OD833 behind my BB 86 RC [Re: WO23Coronet] #1899707
08/26/15 01:01 PM
08/26/15 01:01 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
It's a factory dual pattern bell for a truck four speed and the OD833, but you could put any 833 four speed with the correct ring.
Moparlee
Re: 518 to OD833 behind my BB 86 RC [Re: savoy64] #1899714
08/26/15 01:05 PM
08/26/15 01:05 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I'm really not going to be hot rodding this thing around....ya I wouldn't mind getting that kit.....but to be honest..... I'd rather have his five speed.....and with my change over.... I can go that way when I get rich....lol
Moparlee
Re: 518 to OD833 behind my BB 86 RC [Re: Robbins] #1899722
08/26/15 01:19 PM
08/26/15 01:19 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
The flywheel that I got from a member and the clutch package from Brewer's Performance.
Moparlee
Re: 518 to OD833 behind my BB 86 RC [Re: Robbins] #1899725
08/26/15 01:22 PM
08/26/15 01:22 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Clutch package
Moparlee
Re: 518 to OD833 behind my BB 86 RC [Re: Robbins] #1899807
08/26/15 03:36 PM
08/26/15 03:36 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Brewer's Performance....rebuilt a shift box for me and made it a bolt on shifter for the Pistol Grip.
Moparlee
Re: 518 to OD833 behind my BB 86 RC [Re: Robbins] #1900459
08/27/15 03:45 PM
08/27/15 03:45 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
You can still get a new rod that goes threw the firewall.....thanks Jim.
Moparlee
Re: 518 to OD833 behind my BB 86 RC [Re: savoy64] #1906069
09/04/15 12:32 AM
09/04/15 12:32 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I've seen a two wheel drive one out of cheby on the floor at a friends place (back in the 90's) and it had the Mopar bellhousing pattern.
Moparlee
Re: 518 to OD833 behind my BB 86 RC [Re: Robbins] #1907803
09/07/15 01:18 AM
09/07/15 01:18 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Nice job! That's the same thing I did. Lucked out on finding a bell housing.
Re: 518 to OD833 behind my BB 86 RC [Re: Robbins] #1910289
09/10/15 11:35 PM
09/10/15 11:35 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I finally got the trans pulled today.
Moparlee
Re: 518 to OD833 behind my BB 86 RC [Re: Robbins] #1910290
09/10/15 11:38 PM
09/10/15 11:38 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
I got a bracket from Schumacher(?).....I hope it works.....hopefully it'll let me keep the 518 cross member.
Moparlee
Page 2 of 3 1 2 3
