70-1 A body Rallye dash bezel #1735458
01/21/15 10:52 AM
01/21/15 10:52 AM
Phila Pa
scatpacktom Offline OP
Phila Pa
I'm in the position of needing both a 70 and 71 A body Rallye dash bezel. I have two excellent candidates for replating but I also see there is brand new bezels on the market. Is there a reason I should go one way or the other? I need two, so cost is a little concern but it is not the only concern.
Any insight would be great.
Re: 70-1 A body Rallye dash bezel [Re: scatpacktom] #1735459
01/21/15 11:04 AM
01/21/15 11:04 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I needed to make a decision whether to restore my original 1970 Rallye dash or purchase a reproduction. In the end, I purchased a new reproduction dash. My original bezel had no remaining "chrome" on it and I was concerned about how durable it would be after refinishing.
I am very happy with the finish and fit of the repro bezel. I would be glad to forward you some close-ups if you would like to see more detail.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 70-1 A body Rallye dash bezel [Re: FJR doc] #1735460
01/21/15 11:34 AM
01/21/15 11:34 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 70-1 A body Rallye dash bezel [Re: ScottSmith_Harms] #1735461
01/21/15 01:36 PM
01/21/15 01:36 PM
Phila Pa
Phila Pa
Can you tell me more about the problems you had with the repops Scott. What did you have to do?
Re: 70-1 A body Rallye dash bezel [Re: scatpacktom] #1735462
01/21/15 02:55 PM
01/21/15 02:55 PM
Phila Pa
Phila Pa
I guess I could offset the cost of the repops by selling my bezels but that in itself raises a red flag. People must want the old junk for a reason
Re: 70-1 A body Rallye dash bezel [Re: scatpacktom] #1735463
01/21/15 03:33 PM
01/21/15 03:33 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I had minimal issues installing my repro bezel/ instrument cluster in my Rallye dash.
Kevin
Re: 70-1 A body Rallye dash bezel [Re: FJR doc] #1735464
01/21/15 03:55 PM
01/21/15 03:55 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Who's the best to get them from?
Re: 70-1 A body Rallye dash bezel [Re: ademon] #1735465
01/21/15 03:59 PM
01/21/15 03:59 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I got mine from BE&A.
Kevin
Re: 70-1 A body Rallye dash bezel [Re: ScottSmith_Harms] #1735466
01/21/15 04:21 PM
01/21/15 04:21 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
New bezels:
Good:
Easy to source
Chrome is very durable
Final fit is ok
Cost will normally run a little lower compared to restoring an original
Bad:
While fit is ok, the 2 I've installed were a PIA and needed to be tweaked to install them, it was not a simple drop in.
Chrome is pretty, but not original, it is actual chrome plating vs vacuum metalized as factory so they do look a bit different and a bit too "shiny", they are different enough that I can easily spot one when I see one in a car.
I had both on hand, 2 restored ones and 2 reproductions, so I had free choice between them when doing my cars. I went with originals in my cars. Originals with new vacuum metalizing hold up better than they originally did simply because of the (invisible)urethane top coat they get, it makes them quite durable. Instrument Specialties restored my last one and it's beautiful.
Scott is correct as always, the reproduction with real chrome shines way better than an original and is not susceptible to wiping off with repeated cleaning like the original. Vacuum metalizing was an inexpensive alternative to put a "semi" chrome shine on a part.
Re: 70-1 A body Rallye dash bezel [Re: HEMICUDA] #1735467
01/21/15 04:31 PM
01/21/15 04:31 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I don't have a good photo of my entire dash but here's a close up of the repro.
Kevin
Re: 70-1 A body Rallye dash bezel [Re: scatpacktom] #1735468
01/21/15 05:22 PM
01/21/15 05:22 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Tom- I just went through the exact same issue with the bezel for a '70 Dart Swinger. In the end, the repop won out. For one, shipping the original and somewhat brittle plastic to Washington (GCAR), was more than I felt like taking a chance on and two, my lenses were crazed in a few spots. The repop lenses are $215.00 for the kit, so when all was said and done, I would be into either setup for the same amount. While there are some differences, they are so minor that I can certainly live with them and 99.999% of the people in the world will never notice or even care...
FYI- I did send my dash bezel and the woodgrain panel from my GTX to GCAR for rechroming/replating. No other choice there
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 70-1 A body Rallye dash bezel [Re: 70440+6bbl] #1735469
01/21/15 06:28 PM
01/21/15 06:28 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 70-1 A body Rallye dash bezel [Re: ScottSmith_Harms] #1735470
01/21/15 06:33 PM
01/21/15 06:33 PM
MA
steve70 Offline
steve70  Offline
MA
I'm bringing my complete dash to Instrument Specialties on Friday. They do great work but it's nice that a reproduction is available for those with broken or missing bezels.
1970 Challenger T/A 4 speed
Re: 70-1 A body Rallye dash bezel [Re: steve70] #1735471
01/21/15 06:57 PM
01/21/15 06:57 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 70-1 A body Rallye dash bezel [Re: ScottSmith_Harms] #1735472
01/21/15 07:17 PM
01/21/15 07:17 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Mine was cut for the old 70's cassette player, so I'll be buying one soon, chrome was gone anyway.
Re: 70-1 A body Rallye dash bezel [Re: ademon] #1735473
01/21/15 07:24 PM
01/21/15 07:24 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
E
Re: 70-1 A body Rallye dash bezel [Re: ScottSmith_Harms] #1735474
01/22/15 02:14 AM
01/22/15 02:14 AM
Phila Pa
Phila Pa
Thanks for the replys
