Page 2 of 3 1 2 3
Re: Update on my project [Re: BuckeyeBrawler] #1735352
01/21/15 06:00 PM
01/21/15 06:00 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
It's a work of art. Best thing about it is that it has a passenger seat
[img] [/img]
Re: Update on my project [Re: DemonDust] #1735353
01/21/15 06:29 PM
01/21/15 06:29 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I spy a Liberty
I believe it's a Bruno
I think your both right!
Re: Update on my project [Re: FastmOp] #1735354
01/21/15 07:43 PM
01/21/15 07:43 PM
Tucson, Arizona
Tucson, Arizona
I spy a Liberty
I know your right
[img] [/img]
Re: Update on my project [Re: mopartony] #1735355
01/21/15 08:28 PM
01/21/15 08:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The trans is a Liberty WITH a Bruno drive in front of it.
Re: Update on my project [Re: Al_Alguire] #1735356
01/21/15 09:16 PM
01/21/15 09:16 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Cool car
Re: Update on my project [Re: 340RICK] #1735357
01/22/15 02:58 AM
01/22/15 02:58 AM
in a chair
mopartony Offline OP
in a chair
Thanks everyone.
It has been a long build but I want to do it right.
Steff, unlimited has those scoops.
Al you are right, Bruno unit with a Liberty. Waiting on Dyno time to get the numbers from the motor.
Re: Update on my project [Re: mopartony] #1735358
01/22/15 03:18 AM
01/22/15 03:18 AM
in a chair
in a chair
Ok motor and colors..
The motor is a "stock" NASCAR long block. Scott Brown freshened it up. made sure it was all correct and put it back together. We went with a M&M intake. There was a lot of work done to it and 2 Ultra HP Dominators.
Colors, well that is still a bit in the air. But I am getting close to picking.
One option is close to what Billy the Kid Stepp ran. Some changes to it. But if you see it you will get the idea.
option 2 is black with the side body line/panel, like the Demon in the link, the same color as the rearend housing. There will be a stripe up the center of the car with silver accents on that strip. I am thinking to have either silver or black stars up the center of the center stripe.
I will have 2 hoods for it. one with the old school scoop and one with a new style pro-stock scoop. I will also have 2 sets of rims for the car.
Re: Update on my project [Re: mopartony] #1735359
01/22/15 03:52 AM
01/22/15 03:52 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Nice car.
Where is everyone getting there tail light
lens from ?
Re: Update on my project [Re: demon440] #1735360
01/22/15 05:17 AM
01/22/15 05:17 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Re: Update on my project [Re: Jeepmon] #1735361
01/22/15 11:58 AM
01/22/15 11:58 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Oh Yeah !!
Re: Update on my project-little update [Re: tubtar] #1735362
02/16/15 03:27 AM
02/16/15 03:27 AM
in a chair
in a chair
a little update
Car is being pulled apart for body work and paint. paint scheme is set. Big thanks to Peelerboy!!
My painter Ben told me this is his last car. so I am happy and sad about this.
Tin work is coming out of the back, trim is off for polishing, header guy is lined up, wiring and rest of the driver compartment stuff being removed and got the SuperJax, bled and ran them through before putting the car up on them.
Even set the modern scoop on the car to see what it looks like.
Re: Update on my project-little update [Re: mopartony] #1735363
02/16/15 03:28 AM
02/16/15 03:28 AM
in a chair
in a chair
pic2
Re: Update on my project-little update [Re: mopartony] #1735364
02/16/15 03:31 AM
02/16/15 03:31 AM
in a chair
in a chair
drivers view with a finger tip selfie
Re: Update on my project-little update [Re: mopartony] #1735365
02/16/15 03:37 AM
02/16/15 03:37 AM
in a chair
in a chair
up on the super jax
Motor is ready for Dyno, waiting on 512 to be completed both to be done in same "session" and sent down.
as for colors on the scheme, I will just say, silver, black and something close to mood indigo.
Re: Update on my project-little update [Re: mopartony] #1735366
02/16/15 11:13 AM
02/16/15 11:13 AM
ohio
all spooled up Offline
ohio
i like both scoops
Re: Update on my project-little update [Re: all spooled up] #1735367
02/16/15 12:22 PM
02/16/15 12:22 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Do I spy a Speedwire switch panel
Re: Update on my project [Re: mopartony] #1735368
02/16/15 12:26 PM
02/16/15 12:26 PM
Az
Crizila Offline
Crizila  Offline
Az
Beautiful work - everywhere!
Fastest 300
Re: Update on my project [Re: Crizila] #1735369
02/16/15 12:32 PM
02/16/15 12:32 PM
gregsdart Offline
gregsdart  Offline
First class
Re: Update on my project [Re: gregsdart] #1735370
02/16/15 01:10 PM
02/16/15 01:10 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Did you win the lotto or something ,Tony?
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Update on my project [Re: B3422W5] #1735371
02/17/15 03:17 AM
02/17/15 03:17 AM
in a chair
in a chair
Al, yes you do spy a Speedwire switch panel, it is all speedwire.
Don, no I wish. would have been easier. It has been almost 3 years of hard work. Working over 65 hours a week average for the last 3 years to build this thing. It is now really close....
Page 2 of 3 1 2 3
