My Lifters and Magnum block
#1733534
01/18/15 10:34 PM
01/18/15 10:34 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: My Lifters and Magnum block
[Re: MR_P_BODY]
#1733538
01/19/15 04:13 AM
01/19/15 04:13 AM
slammedR/T
Chad.. if you dont mind.. whats a set worth with the offset... I should go with this on my W-5s
I waited three months for these to come out, he had done the resign to fit 3/8" pushrods and was testing them. They are the pro series with all the bells and whistles and ran me $650.00. They are VERY! well made and I am more than happy with them. They don't go to low and expose the oil band, I thought a I had oil pressure issue with them. But I found out couple weeks ago what that was, the grunt at the machine shop didn't clean my block properly. After I grind the lifter bores, I wanted to knock out all the oil galley plugs and clean the block real good with degreaser, galley brushes, then soap and water. Well I had to knock through half the valley length of carbon, gunk, and metal. I wasn't happy at all and let my machine shop buddy and owner know.
[Re: slammedR/T]
#1733539
01/19/15 04:21 AM
01/19/15 04:21 AM
Posts: 52,972 Romeo MI
MR_P_BODY
$650 isnt bad.. only about $100 more than my last set... and I need to PR oil just like you since I run the same rockers ![](/ubbthreads/images/graemlins/wave.gif)
[Re: moparmacka]
#1733541
01/21/15 08:48 PM
01/21/15 08:48 PM
slammedR/T
In short....you would definitely recommend these over the 8043-16 lifter?
Would you need the offset pushrod seat for a W5 and I wonder if they would fit a Mopar 340 Siamese block. I clearanced (only between the lifter bores not the inside valley wall) my block to suit the 8043-16 I borrowed and haven't bought a set of lifters yet.
You may not need the offset lifters with the W5's I needed them with these huge Indy heads though. Give Mike at MRL Performance a call he can help you figure out what you need ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: moparmacka]
#1733543
01/21/15 09:12 PM
01/21/15 09:12 PM
slammedR/T
Cheers I will do before our exchange rate drops off the planet!
I was mainly after feedback and by the looks of it, you are happy with the product.
Have you used these lifters since the Comps broke or this is the first set you have purchased?
Macka
This is my first set after the comps broke, before I had a set of conversion lifetrs that were called "danno" lifters. They are the same lifter body of a factory hydraulic lifter but converted to solid roller and used factory magnum dog bones and retainer plate. I got these when I went to the indy heads and love them ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: slammedR/T]
#1733544
01/21/15 09:25 PM
01/21/15 09:25 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Love my MRLS....
Just thought I'd toss that out there.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
