Starting after air bag deployment #1732927
01/18/15 03:13 PM
01/18/15 03:13 PM
Western Pa
farmboy70 Offline OP
Western Pa
Hi
My Charger was recently in a accident with the side air bag deployment.
The shifter is locked and no start at push button.
I can't start the car to move it.
Is there a relay or fuse that needs reset on side impact?
Wiring in the right passenger area is destroyed under fender I would guess.
Re: Starting after air bag deployment [Re: farmboy70] #1732928
01/18/15 05:44 PM
01/18/15 05:44 PM
Northern NJ
67440dodge Offline
67440dodge  Offline
Northern NJ
Wonder if it's the same as the trucks where you quickly turn the key 3 times to start (or depress run button 3 times?) to override it?
Re: Starting after air bag deployment [Re: 67440dodge] #1732929
01/21/15 02:26 PM
01/21/15 02:26 PM
Western Pa
Western Pa
Turned out to be a jammed shifter, repaired that, cycled the switch and started right up
Re: Starting after air bag deployment [Re: farmboy70] #1732930
01/21/15 05:47 PM
01/21/15 05:47 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Dang Farmboy I hope no one was seriously hurt!!!!!!
Re: Starting after air bag deployment [Re: hemirdrnnr] #1732931
01/21/15 05:58 PM
01/21/15 05:58 PM
Western Pa
Western Pa
No serious injury's, no one was in the passenger side.
Very lucky, thank goodness.
Re: Starting after air bag deployment [Re: farmboy70] #1732932
01/21/15 10:21 PM
01/21/15 10:21 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Good deal easy to replace a car "can't replace family or friend".
Joe
Re: Starting after air bag deployment [Re: hemirdrnnr] #1732933
01/21/15 10:29 PM
01/21/15 10:29 PM
Western Pa
Western Pa
Amen to that.
