Re: Ever consider a crossbreed?
[Re: Monte_Smith]
#1732069
01/18/15 02:21 PM
01/18/15 02:21 PM
Posts: 4,213 New York
polyspheric
New York
with just a small cowl hood
If someone did it, it must be a good idea...?
Boffin Emeritus
[Re: polyspheric]
#1732070
01/18/15 02:52 PM
01/18/15 02:52 PM
Posts: 8,191 Plymouth, MI
Blusmbl
Plymouth, MI
If I could fabricate worth a crap I'd like to do a T56/gen 3 hemi in a gasser style tri 5 Chevy. Also don't mind LS swaps in Mustangs or lots of the BOP stuff.
[Re: bobby66]
#1732073
01/18/15 04:41 PM
01/18/15 04:41 PM
Posts: 485 Central California
MoParFish
Central California
I love the 55-57 Chevy styling. Add 440, Hemi 4-speed and a 4.10 Dana and I'd be set. Either that or a nice '62 Fury.
Steve Parrish races a 55 Chevy with BB Mopar power. Nice guy, has beat me a couple of times. I should have just not even lined with him and saved the fuel He's good. I asked him one time why that combo. As I recall, Steve said back in late 60s??? he had the wagon with no motor and a fury with a good 383 and the rest was history http://www.dragracecentral.com/DRCPhoto.asp?ID=240163
[Re: Hot 340]
#1732074
01/18/15 07:16 PM
01/18/15 07:16 PM
Posts: 728 Southern Alberta
Uberpube
Southern Alberta
I've been playing with the idea of putting a GenIII hemi in one of my Rx-7's. I can buy a 6.4 crate motor now for cheaper than what it costs just for parts to rebuild a 3 rotor.
Exactly the car I was thinking about.. Hows the rear suspension on those?
Pretty tunable, lots of parts to make it a drag racer or a road racer. The diff is fairly tough, I did blow one up with a dog box and sticky tires.
[Re: TRENDZ]
#1732075
01/18/15 07:24 PM
01/18/15 07:24 PM
Uberpube
Southern Alberta
. [/quote
Did this for a guy that wanted a powerful mazda...
Thats a fairly common swap, and also a fairly common point of failure. The Last long high speed corner of our road racing track has claimed a lot of LS motor main and rod bearings, hence why I would want to try a Hemi. The rotary makes a ton of power, and has a much more reliable oiling system, its just the availability and cost of parts that is the downer, especially for the 3 rotors.
[Re: Uberpube]
#1732076
01/18/15 07:38 PM
01/18/15 07:38 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
He tried the three rotor before this. Hated the pre boost tq. This car has an independent 8.8 with much heftier halfshafts, and a more "engine correct" gear ratio. This is the aluminum block ls.
[Re: knyech1]
#1732083
01/18/15 10:01 PM
01/18/15 10:01 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I think I am being stupid, but haven't totally made up my mind this is the last text he sent.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1732084
01/18/15 10:02 PM
01/18/15 10:02 PM
1967dartgt
Hilltown Pa
![](http://i1274.photobucket.com/albums/y434/1967dart/439D59B6-DF23-4A0F-9CDE-59AD226B3D99_zpsknlwgjih.jpg) This is the car.
