I have a brand new set of Hughesengines 1107 dual coil valvesprings that have an Outer spring that measures 1.510 outer diameter with the inner spring having a inner diameter of .800
These are going on a set of 440 Source heads which i think have 11/32 valve stems with single groove?
I would li
