Re: volare front clip in a Studebaker pickup need advice
[Re: mikeysmopars]
#1727380
01/11/15 09:51 PM
01/11/15 09:51 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
First, decide if a Volare is what you really want. Are parts available? Will they be in 10 years when it's time to refresh?
Okay, now what is the wheelbase and track width of both the truck and the donor? WB will affect the ackerman. Track width will affect wheel selection and looks.
Next, line up the truck on the floor and mark out front body mount, radiator location, wheel location, firewall location and steering column/box location. Also mark out the frame rail width from the axle centerline to the back of the cab.
Move the donor to the same spot and mark the same things.
Make plans for each variance. Will the sheetmetal and radiator mount work? Will the sheetmetal clear the frame? Will the engine clear front and back? Will the engine still fit in the new frame location? will the steering column enter the cab at the same point and angle? Will the 2 frames cross at a point where splicing and boxing are realistic? What is the plan for the brake master? What about radiator hoses, brake lines, exhaust and other routing?
[Re: RodStRace]
#1727381
01/11/15 10:11 PM
01/11/15 10:11 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
A friend of mine bought one of those clips at a yard recently and wanted to hang it on the front of a '56 Plymouth that he is building. He asked me for advice and since I had never done one, I asked a rod builder that I respect about the process. The builder had done a few of those, but not recently and does not recommend them because they were not that good to begin with and now those parts are 40 years old ![](/ubbthreads/images/graemlins/eeek.gif) I remembered that I worked at a NAPA store in Kirkland when the Aspen / Volares were new and had conversations with the techs in the Kirkland, WA motor pool. They had ongoing problems keeping the police cars in alignment. It comes down to this, if you are going to build a high dollar street rod why would you want to build it with worn out parts??? Do yourself a favor and get an IFS kit from a reputable rod chassis shop and have it professionally installed. ![](/ubbthreads/images/graemlins/Twocents.gif)
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: RodStRace]
#1727382
01/11/15 10:36 PM
01/11/15 10:36 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Parts for that clip are all readily avalible,brakes,bushings,suspension,steering,all mother Mopar and engine bolts directly in. Just would like to see pictures and how to determine ride height. I'm very capable of welding it in just want to make sure it's in correctly.
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: Dabee]
#1727385
01/12/15 12:31 AM
01/12/15 12:31 AM
Posts: 1,106 Northeast
VincentVega
Northeast
F/M body isolated front end has a multitude of problems, but that being said you probably won't get killed from using one. The cop cars exposed some metallurgy and quality issues that eventually got dealt with.... so you'd probably want a unit out of a late 80s gran fury or diplomat rather than a late 70s F body. But any would work.
The issue you'll never be able to deal with is the wandering. The lower control arms are double-jointed so to speak, one rubber joint on the control arm, and then the rubber pivot joint on the torsion bar that doubles as the strut. this tends to make them follow the grooves even a little more than your standard mopar. I drove a 79 Lebaron and then 81 diplomat for years and you tend to get used to it. they're flawed designs, but it will get you around.
I think if you came up with a auxiliary strut arm or radius rod and gusseted the upper control arm towers it'd be fine. And if you do that, be sure to sell the patent to one of the aftermarket guys
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: mikeysmopars]
#1727386
01/12/15 12:51 AM
01/12/15 12:51 AM
Posts: 10,649 Freeport IL USA
poorboy
Freeport IL USA
Its been a while. If I remember correctly, the original mounting ears were designed to be level with earth (front to back, and side to side) at ride height (ride height is important). That should set the upper control arms with the rear lower then the front by about an inch, to an inch and a half,(there is quite a visible difference, if you have an opportunity to see one still installed in a car, look at the upper control arm angles) from level. You need to be sure you have the spindles centered in your wheel openings, and square to the truck. You also need to set the distance from the frame correct for your ride height and clearance when everything is done. Though there is some height adjustment, cranking the cross torsion bars up will be short lived, they tend to settle down pretty fast when they are under load, and there is very little it can be lowered. Its important that the K member be set and positioned correctly, then adapt the frame to meet the correctly positioned K member. Resist the temptation to adapt the K member mounting to making attaching to the frame easy. Compromising the correct location of the K member for ease of installation is most often what gave these clips a bad rep. The other issue is the torsion bar mounting pieces, (and other worn suspension) be sure yours are good.
If you are using the original steering box, be watchful of the angle of the column and the steering column clearance with the motor & firewall. The box sits back on the K member and it tends to have a pretty steep angle for the column on old trucks. Steering U joints can only handle about a 25 degree angle from straight, the the box is close to the firewall (at least was on the 3 I did).
The Volare suspension gives a great ride under a mid 50s truck (I had one under a 54 Dodge pickup). They tend to feel a bit mushy if you do spirited corners, and bigger sway bars are the only fix. The brakes are excellent, especially if combined with 10" or 11" rear brakes. Two of the 3 vehicles I installed these clips under were my personal vehicles. One went 70,000 after the install without issues, and the other went 40,000 miles without issues. Both vehicles were sold for different projects.
The later versions of the K member (from 5th Ave/Diplomats) had a reinforcing bar added under the upper control arm, bolted to the adjusting plate. The extra reinforcing plate helped the alignment issue the early cars had.
You have the K member in hand, and it looks pretty clean. Mount it correctly, and use it. That said, there are better and more easy to mount clips available these days, for your next project. Gene
[Re: poorboy]
#1727387
01/12/15 02:40 AM
01/12/15 02:40 AM
mikeysmopars
fresno ca
Thanks for your info,the clip I have is very decent and your right about the Dakota clip but we are building this project with limited funds and got the clip to next to nothing. Truck is a 64 Studebaker with 69 440,727,8 3/4 but wanted to shed the straight axle. Anyone have pictures of thier build? Would Appreciate some. Thanks! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Polarapete]
#1727389
01/12/15 02:13 PM
01/12/15 02:13 PM
Posts: 1,444 NEW JERSEY
dynamite
NEW JERSEY
I put one in my 56 Plymouth ..and it's great..I now have disc brakes and power steering , and t/b suspension..car runs low 11's gone thru the traps at 119 mph straight and smooth.. and I have driven it from FL to NJ and back twice..RB power Mine is from a 1986 5th ave that I bought for $259 with bad motor..Got the whole car ,used the steering colume and anything else I could take....Easy install ..remove the coil spring ,weld a flat plate on the inside and notch the frame for the pads and go..
[Re: poorboy]
#1727392
01/12/15 08:52 PM
01/12/15 08:52 PM
mikeysmopars
fresno ca
Thanks, I'm going to make sure all the weight is in the pickup and check & adjust for ride height before we do any cutting.My cousin did exactly what your talking about which is why i'm on here getting as much info as i can before i cut. Thanks!! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: mikeysmopars]
#1727395
01/13/15 01:24 AM
01/13/15 01:24 AM
poorboy
Freeport IL USA
On my 54 Dodge, I cut the original frame off 11" in front of the front cab mounts and welded a 2" x 4" tube subframe into the existing truck frame, that area was boxed closed. Then I built mounts and bolted the K member to my new tube rails. I tied the front of the tube rails together with a tube end cap that sat below the side rails. This front tube was welded and gusseted to the side rails. The front tube served as a bumper bracket location, as a radiator surround support which was also front fender support.
The original frame rails on my Dodge were 6" high. I installed the tubing with the top of the tube 1" above the original rails, and my truck sat too low. The bottom of my front bumper was beat up bad, as were the leading edges of the running boards. A 12 oz pop can just fit under the front of the running boards and they scrapped many places.
If you intend to mount the Volare clip by the mounting brackets, the front 2 bolt holes are 4" on center wider then the rear 2 mounting bolts. My tube rails were composed of 2 sections of the tubing, welded side by side about midway to the front, the wider section towards the front. Unfortunately, all of my pictures of the truck construction went with the truck. There may still be a poor picture of the black painted frame, I will see if I can find it. Gene
