Re: Throttle Linkage for Tunnel Ram and Inline Carbs?
[Re: 67Satty]
#1723230
01/06/15 02:11 PM
01/06/15 02:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Two Holley 1850s mounted inline.
I used my regular throttle bracket(where the cable mounts) on the rear carb and made a 3/16 shaft and 2 small 3/16 heim joints to attach the 2 throttle arms.. I made up 2 nylon bushings to go in the large hole and a large washer to bolt the heim into that hole
[Re: DJVCuda]
#1723232
01/06/15 04:23 PM
01/06/15 04:23 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
Thanks for the ideas and replies so far. I'm thinking about going to the hardware store and getting a rod that is threaded on both ends and two female-thread heim joints for each end to go into the throttle arm as seen on this page: https://fordmuscle.com/archives/2004/08/ThrottleLinkage/index.phpIt's just the part that attaches to the throttle arms that I don't like on the Summit kit. So I think if I can take the idea from above and use it with the rest of the Summit kit (the part of the "T" that goes down) that might work.
[Re: 67Satty]
#1723233
01/06/15 04:43 PM
01/06/15 04:43 PM
MR_P_BODY
The attachment point to the carb in your link is how I did mine
[Re: 67Satty]
#1723235
01/06/15 04:59 PM
01/06/15 04:59 PM
MR_P_BODY
Yeah, that's the part of the Summit kit I don't like - how it attaches to the carb's throttle arms - seems flimsy. See I'm going to try to do it how you did it and how they show it in the link.
I think its Holley that sells the bushing/insert part that goes into the large hole.. I just made mine... then the rod between the 2 carbs is easy
