Re: 4 speed pedals uneven??? [Re: SCATPK] #172218
12/23/08 12:37 AM
12/23/08 12:37 AM
Rome, PA
Ryan_340 Offline
Ryan_340  Offline
Rome, PA
Even the clutch pedal in my 1992 Dakota sits higher than the brake pedal.
1972 Power Wagon W100 1973 Power Wagon W200 1971 Duster 1972 Dart Swinger 3-1972 Demons
Re: 4 speed pedals uneven??? [Re: Ryan_340] #172219
12/23/08 09:01 AM
12/23/08 09:01 AM
Ontario, Canada
6pktgo Offline OP
6pktgo  Offline OP
Ontario, Canada
Many Thanks for all your responses. I think i`m going to install the column this morning and do a dry run electrical test and hope for the best. My 6 pack engine arrives shortly and i`ll fasten that and the 4 speed together to the K member and slip these in from the bottom. I would have liked to post some pics but i can`t figure out how and i`m not that good on the comp. If you`d like a pic or two i can do that by email anital@eagle.ca Thanks Again to Moparts !!
Re: 4 speed pedals uneven??? [Re: 6pktgo] #172220
12/23/08 03:39 PM
12/23/08 03:39 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
I would imagine that, after you do the electrical test to make sure everything works, you'll remove the column before installing the K-frame/engine/trans/steering gear. Otherwise, you may have some trouble getting the K-frame to line up without bumping into the the bottom of the column shaft on the steering box input shaft. I plan on doing mine this way as well, but haven't done it yet. Just seems like it could be an issue. Others have installed from bottom before and chime in with their experiences.
Re: 4 speed pedals uneven??? [Re: MoparMarq] #172221
12/23/08 06:36 PM
12/23/08 06:36 PM
Ontario, Canada
6pktgo Offline OP
6pktgo  Offline OP
Ontario, Canada
I was up under the dash looking real close and there`s no more room for the brake pedal to rise up as the linkage has no room left to travel.I also have 3-70 Chargers all p/b cars and all the linkages are the same.
Re: 4 speed pedals uneven??? [Re: 6pktgo] #172222
12/23/08 07:22 PM
12/23/08 07:22 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Your pedals are correct, car is much nicer to drive when the brake and gas pedal are fairly close, if you watch a nascar race they sometimes show the drivers foot quickly going between gas and brake pedal which are about even, Not sure why some cars have the brake pedal even with the clutch, maybe bent or wrong pedal, problem/wrong booster.
Re: 4 speed pedals uneven??? [Re: ademon] #172223
12/24/08 09:57 AM
12/24/08 09:57 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
well, our pedels are way offset also. everything appeard to be original to the car before we restored it. and again, there wasn't any more room for adjustment for the break pedel to come forward. the car is a 70 charger with power drums
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
