STR-14 dyno test revisited--UPDATED
#17199
09/03/05 11:58 AM
09/03/05 11:58 AM
Posts: 14,545 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
eariler this week i had the chance to dyno test an Edelbrock STR-14 intake. the motor is out of a customers race car, and is here for freshening, and hopefully an increase in power. since i had never had the chance to run one of these intakes before, i wanted to test it before pulling the motor apart, and to baseline the motor overall as it came out of the car(to try and help determine if the car was running like it should for what the motor is making for power).
the basic build is: 446(unknown CR, but it has just over 190psi on a comp. test) stage III ported E heads by Compu-Flow Herbert roller cam, 246/253 @ .050, .585/.600 lift, 107lsa HS 1.5 rockers Indy reverse flow cooling 1 7/8" X 3" headers with 18" extensions
i tested 3 different intakes on this motor. my Holley SD-4500 intake with a mildly reworked non-HP 9375 carb, a Weiand TR with 2 Carter 750 AFB's, the TR with the Ebrock 600's that the owner was running on the STR-14, and the STR-14 with the Ebrock 600's.
i made several warm up pulls for each combination, and made sure the numbers would repeat within 1-2hp, which they did for all the combinations.
here are the numbers:
RPM-----SD/1050---TR/750----TR/600---STR/600 ---------TQ/HP-----TQ/HP-----TQ/HP-----TQ/HP 3700----522/368---555/391---558/393---528/372 3800----536/389---566/410---567/410---536/388 3900----548/407---566/420---572/425---548/407 4000----552/421---569/433---572/436---546/416 4100----554/432---572/446---570/445---545/426 4200----555/444---569/455---565/452---547/438 4300----557/456---565/463---564/462---547/448 4400----559/468---564/472---570/477---548/459 4500----561/481---569/487---566/485---550/471 4600----560/491---571/500---568/498---543/476 4700----556/498---569/509---568/509---540/483 4800----549/502---567/518---567/518---537/491 4900----548/512---564/526---562/525---530/494 5000----544/518---558/531---557/530---531/505 5100----542/526---554/538---546/530---525/510 5200----535/530---542/537---544/539---518/513 5300----534/538---535/540---542/547---513/517 5400----526/541---527/542---530/545---504/518 5500----519/544---525/550---526/551---496/519 5600----517/552---513/547---511/544---490/523 5700----513/556---504/547---505/548---479/520 5800----502/554---491/542---489/540---468/517 5900----494/555---479/538---483/542---466/523 6000----485/554---466/532---471/538---459/525 6100----474/551---463/538---462/536---452/525 6200----464/548---454/536---456/538---446/527 6300----456/547---448/538---449/538---429/515 6400----443/540---442/538---436/532---421/513 6500----437/541---428/530---432/534---405/501
as mentioned in another thread, this particular STR-14 has a home made top piece, which is seperated from the base by a 3/4" piece of some sort of plastic. the carbs are mounted sideways, like an OE MW motor, with the primary barrels towards the outside of the intake.
i'll take a couple of pics of it next time i'm down at the shop.
the motor came out of a 63 B body that weighs 36-3700lbs, was running a 10" Trans-King converter which flashed about 4000, and 4.56 gears, and he was using 1 7/8 headers but was not running the reverse flow cooling system in that car.
the car was a low-11 sec combo(typically teens-20's), and never broke into the 10's.
Re: STR-14 dyno test revisited
[Re: fast68plymouth]
#17201
09/03/05 01:06 PM
09/03/05 01:06 PM
Posts: 1,118 Central Missouri - USA
Ramcharger
super gas
super gas
Here are some comparisons for those who are interested: -----------Peak HP-------Peak TQ-----Avg. HP---Avg. TQ -----SD--556 @ 5700---561 @ 4500-----502-------522 -TR 600--550 @ 5500---571 @ 4600-----505-------527 -TR 750--551 @ 5500---570 @ 4400-----505-------527 STR 600--527 @ 6200---550 @ 4500-----484-------505 Very interesting. I wonder why the STR makes it's peak HP so much higher that the other 3? Is it due to the larger plenum volume or...??? Well, the STR may be down 18-21 HP and 17-22 lb.ft. of TQ compared to the others, but it has a more unique look than the SD/4500 and it will fit under the hood (and a Max Wedge hood scoop) on my 64 unlike the tunnel-ram. Hey, I have to justify it to myself somehow... A big thanks to Fast for the numbers. For those of us using "old tech" pieces like the STR, its nice to know how it compares to more modern set-ups. Fast, if/when you ever test the OE STR and the MW X-ram, I would be very interested in the results. I was very surprised to see how little the numbers on the TR changed with the different carbs. I knew that there would not be a big difference, but I thought it would be a little more apparent. I wonder what kind of difference there would be between the Weiand and an M-1 TR. I just happen to know where one is sitting on a shelf if you would like to compare...
'64 Dodge 440 2 dr. sedan - 440/pushbutton 727 (in the body shop) '99 Dodge 2500 Quad Cab Long bed 4WD - CTD 5 spd. 3.54 '89 Dodge 150 4x4 - 5.9 TBI/727 35x12.50's and 8" lift '14 Dodge Dart Limited 2.4/6-speed A/T
[Re: Ramcharger]
#17202
09/03/05 01:18 PM
09/03/05 01:18 PM
fast68plymouth
So. Burlington, Vt.
this TR has had the two halves matched to each other, and has been gasket matched as well. the Holley SD has been made into a 4500 intake by welding a plate to the top of the plenum, and then blending that into the original casting, however it has not had any work done to the runners themselves.
the STR-14 had the mods recommended in the old DC engine book done to it, which the owner says were worth almost a tenth in the car.
if you look in the tech archives at the original Ebrock head tests, you'll see the TR was better than the Holley 4500 on that motor by about 20-25hp(same two intakes). so, it looks like as the power level goes up, the TR starts to show even more promise. however, on that test i was using two modified Speed Demon 650's. ive since sold those carbs, but am going to get together a pair of ProForm bodied carbs for future testing. at some point i'd like to test the Weiand TR against the MP TR(which i have as well....but it needs a little tweeking before being put into service).
on a 528 with BS heads, a "cleaned up" MP TR with 2 X 750 Holleys kicked the crap out of a single plane M1 with an 1150 carb on a 4150/4500 adapter by about 60-70hp IIRC(i'll have to check my notes).....so i think it might be a pretty good piece.
EDIT-just checked my notes.....the MP TR was 50hp better on that 528. 690hp vs 740hp, and the peak TQ went from 690 to 715.
[Re: Ramcharger]
#17205
09/03/05 10:39 PM
09/03/05 10:39 PM
fast68plymouth
So. Burlington, Vt.
ive never done the back to back test(on either the dyno or in the car) so i cant say for sure, but i know of at least one board member who has swapped from Ebrock 750's to some high dollar Holley 750's and saw no difference in ET.
i just like the Holleys better, so thats what i'll end up using. i got everything all set up for the Holley/Proform carbs on the Weiand today, just need one more Proform body to arrive(should be here Tuesday) and it will be a ready to install & test intake/carb combo.
i'd really like to try it on an E headed stroker combo with a pretty good sized cam and see how it works on the bigger motor.....and at the same time compare it with the MP TR.
#17206
09/04/05 09:41 AM
09/04/05 09:41 AM
fast68plymouth
So. Burlington, Vt.
here's a pic of the STR-14 with the home made top(see attach). you'll see the carbs are also mounted on top of 2" spacers. these are open spacers.
Ramcharger, do you have any pics of how you did the linkage on your STR-14??
#17207
09/04/05 09:43 AM
09/04/05 09:43 AM
fast68plymouth
So. Burlington, Vt.
here is looking from the back of the motor. the cable pulls sideways on the bottom of the lever, which is hooked to a shaft that runs under the plate between the two carbs and attaches to the other carb up front.
[Re: TonyS451]
#17216
09/06/05 02:55 PM
09/06/05 02:55 PM
Posts: 810 Sidney Ohio
9SecRoadRunner
Sidney Ohio
My brother and myself switched from wieand TR's to M1 TR's and seen no noticable difference other then increased hood clearance, no performance change noticable, mine was on a fairly mild 440 in a 63 dodge running 11.20's-11.30's, his was on a 383 duster running 10.70's-10.80's on a side note, I did switch from 2 500 cfm carter comp series too 2 750 cfm carter comp series on the same 63 dodge and picked up a solid tenth, maybe 1.5 mph, most of the gain came in the 60'! then I switched too 2 750 cfm ebrocks and they ran the same as the 750 carters...as noted earlier a switch to 2 750 race prepped dp holleys made no noticable et gain over the carters on an indy headed 440 a run down on the car, 63 dodge, 3540lbs w/driver 4.56 dana on leaf springs, 13x31" rear tire, 10" street/strip type convertor, .060 440 , stock crank&rods, KB pistons, home ported heads w/ 2.14/1.81 valves, 10.5:1 comp ratio, cam was an old lunati .540/.563 lift and 261/271 duration @ .050, TR 2 750's, car ran 11.20's - 11.30's @ 119 with 1.57-1.58 60' , fun car, wish I had it back
