Re: Locked distributor advance [Re: Bigbeep] #172052
12/22/08 01:23 PM
12/22/08 01:23 PM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
Every single person who has ever physically broken one of our starters has been running a crank trigger or a distributor with locked advance. About half of them were using electronic start retard which doesn't seem to always work very well.
We recommend two triggering devices with the second trigger retarded about 20 degrees from the first. You can add a second pickup to the crank trigger arm, or you can add a pickup to the distributor. Start the engine using the retarded trigger and then use a switch on the dash to move to the advanced pickup after the engine starts.
The single light spring in the distributor mechanical advance will work but make sure the advance mechanism always returns to zero. If the mechanism gets a little sticky, the weights won't return all the way using only one light spring.
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
Re: Locked distributor advance [Re: RobbMc] #172053
12/22/08 02:20 PM
12/22/08 02:20 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
Anyone running locked timming on the street?
Re: Locked distributor advance [Re: RobbMc] #172054
12/22/08 02:23 PM
12/22/08 02:23 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My distributor has been locked for 6 years..Compression ranging from 11.8 to 13.3....no start retard or anything, has never kicked back, and start it with the key just like from the factory.
I like it, makes tming it easy(if your light is good)
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
Best so far, 10.32 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Locked distributor advance [Re: B3422W5] #172055
12/22/08 02:46 PM
12/22/08 02:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run the springs in my MSD dist, no problems with
starting at 14.1:1
Re: Locked distributor advance [Re: Blown61] #172056
12/22/08 06:42 PM
12/22/08 06:42 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
yes
a freind bent the ring gear on his converter and had sent it to turbo action to fix it
when he put the msd retard box in there where no more problems with it
1.39 9.85 - 137 mph
Re: Locked distributor advance [Re: Ari440] #172057
12/22/08 07:53 PM
12/22/08 07:53 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
I always lock them out, run better, idle better, never a problem staring even with my 13-1 engine... Ive even locked out stock mopar distributors...
Re: Locked distributor advance [Re: BB70DUSTER] #172058
12/23/08 12:07 AM
12/23/08 12:07 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Locked in at 35deg .
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Locked distributor advance [Re: chryco] #172059
12/23/08 12:41 AM
12/23/08 12:41 AM
will the lean burn distributor work for a locked distributor?
Re: Locked distributor advance #172060
12/23/08 01:15 AM
12/23/08 01:15 AM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
10-4
Re: Locked distributor advance [Re: Quicktree] #172061
12/29/08 01:22 AM
12/29/08 01:22 AM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
One light spring, interesting
How soon do you get full advance with that setup (MSD dizzy)?
as soon as it starts
problem only running one spring is you some time get rpm's going up and down. if you run one light silver and one light blue it will keep it stable and accomplish the same thing
The silver springs are the lightest, correct?
Why use a blue spring then?
I think I have two silvers in mine at the moment.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Locked distributor advance [Re: Sledge_57] #172062
12/29/08 02:35 AM
12/29/08 02:35 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Since it appears most are in favor of locking out the distributor.. Whats the easiest way to lock out a MSD?
Re: Locked distributor advance [Re: Jeepmon] #172063
12/29/08 04:25 AM
12/29/08 04:25 AM
Vallejo California
T748 Offline
super street
T748  Offline
super street
Vallejo California
Re: Locked distributor advance [Re: sixpackgut] #172064
12/29/08 05:00 AM
12/29/08 05:00 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I've offered this once before.
Buy a set of light advance springs.
Remove the two installed springs, install one of the light springs.
Advance is very quick and no starting problems. For the street, you can't beat this little trick
Paul
one light spring
same here..... them big garage door springs suck....
Mopar Performance
Re: Locked distributor advance [Re: moparniac] #172065
12/29/08 08:31 AM
12/29/08 08:31 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
Is this on a MSD or a Mopar dist. I have a set of morso light springs I have thaught of putting in my MSD.
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: Locked distributor advance [Re: Jeepmon] #172066
12/29/08 10:56 AM
12/29/08 10:56 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Yes, every engine that idles above 3,000 RPM will do quite well with locked advance.
Others... not so much.
If your engine runs the same with and without advance, there is something wrong with your cam, carb or both.
Boffin Emeritus
Re: Locked distributor advance [Re: T748] #172067
12/29/08 02:22 PM
12/29/08 02:22 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
