'73 440 Motor with a Forged Crank? #1720549
01/03/15 12:42 AM
01/03/15 12:42 AM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
I have one. Could this have come from a truck or motorhome? It has a harmonic balancer that is definitely not for a cast crank motor. The motor has not been taken apart, except that someone has taken the motor mounts and exhaust manifolds.
Re: '73 440 Motor with a Forged Crank? [Re: 3_RTs] #1720550
01/03/15 12:47 AM
01/03/15 12:47 AM
Northeastern PA
Fanning Offline
Fanning  Offline
Northeastern PA
What are the numbers on the top pad?
Re: '73 440 Motor with a Forged Crank? [Re: 3_RTs] #1720551
01/03/15 12:49 AM
01/03/15 12:49 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
thick balancer would point towards a cast crank
Re: '73 440 Motor with a Forged Crank? [Re: 3_RTs] #1720552
01/03/15 12:53 AM
01/03/15 12:53 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
i had a motorhome 440 with steel crank,sixpack rods and 213 heads
Re: '73 440 Motor with a Forged Crank? [Re: 3_RTs] #1720553
01/03/15 12:55 AM
01/03/15 12:55 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
NO , the cast crank was phased in during the 73 model year , I had a non HP 440 -4 wit ha forged crank and LY rods.
Re: '73 440 Motor with a Forged Crank? [Re: Fanning] #1720554
01/03/15 12:57 AM
01/03/15 12:57 AM
Missouri
3
3_RTs Offline OP
3_RTs  Offline OP
Missouri
The numbers on the top pad are J440 and 11 21. There's nothing else there.
Re: '73 440 Motor with a Forged Crank? [Re: 3_RTs] #1720555
01/03/15 01:04 AM
01/03/15 01:04 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I just tore down a J 440 and it had a forged crank also.
Re: '73 440 Motor with a Forged Crank? [Re: 3_RTs] #1720556
01/03/15 01:47 AM
01/03/15 01:47 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I believe the transition to cast was in April, '73...
Balancer tells the story...
What's the block casting date???
Re: '73 440 Motor with a Forged Crank? [Re: 3_RTs] #1720557
01/03/15 01:59 AM
01/03/15 01:59 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
I pulled a steel crank 440 out of a '73 Imperial, and have pulled 4 or 5 out of trucks and motorhomes up thru '75 with steel cranks. They all had heavy rods.
Re: '73 440 Motor with a Forged Crank? [Re: vdriver] #1720558
01/03/15 02:22 AM
01/03/15 02:22 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Chrysler had a tendency to use up what was laying around. If someone found a skid load of 440 cranks laying around in a warehouse someplace, they would have put them in the next batch of motors.
Such was reportedly the case of the 6 pack crank and rods being used after the cast cranks were originally being installed.
By the mid 70s, there weren't a lot of 440s being installed in anything. Chrysler would built motors bu batch loads, 440s this week, 400 next week and so on (time frames used as a reference only) Then as the specific motor was ordered, someone went and picked one up from the available batch (in simple terms) and it was installed. A batch of motors could have been built and sitting for a while before a new batch was run.
This should get the BS flowing! Gene
Re: '73 440 Motor with a Forged Crank? [Re: d-150] #1720559
01/03/15 02:27 AM
01/03/15 02:27 AM
missouri
ragin sonny Offline
ragin sonny  Offline
missouri
I've got two 73 motorhome 440's each with one 213 head one 902 head.one set with cooling holes small plugs,one set with regular plugs no cooling holes.strange
Re: '73 440 Motor with a Forged Crank? [Re: poorboy] #1720560
01/03/15 02:29 AM
01/03/15 02:29 AM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Guess it could be possible in a heavy duty application. A few years ago my old boss had a huge 73 motor home he tried selling me for the motor he claimed was a 440, but I discovered it actually was a 413 with a steel crank.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: '73 440 Motor with a Forged Crank? [Re: G-Money1320] #1720561
01/03/15 03:20 AM
01/03/15 03:20 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Any big block with a manual trans, right up to when they quit building them will have a steel crank in it. No cast crank manuals.
Kevin
Re: '73 440 Motor with a Forged Crank? [Re: 3_RTs] #1720562
01/03/15 03:39 AM
01/03/15 03:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
73 440 assembled 11/21/72 , should have had a forged crank , nothing special or secert about it .
Re: '73 440 Motor with a Forged Crank? [Re: JohnRR] #1720563
01/03/15 11:29 AM
01/03/15 11:29 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Cast crank started in mid-73.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: '73 440 Motor with a Forged Crank? [Re: moparmarks] #1720564
01/03/15 11:39 AM
01/03/15 11:39 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
All the '73's I have seen in the field had steel cranks, I have one under the bench now. That doesn't mean no cast cranks 440's were made in '73.
I might have just lucked out in my area.
"I think its got a hemi"
Re: '73 440 Motor with a Forged Crank? [Re: gdonovan] #1720565
01/03/15 06:41 PM
01/03/15 06:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
All '73 440 HP motors got forged cranks, the STD 440 could have either cast or forged at random.
This is the subject of TSB 09-01-73C dated October 11, 1972:
"The standard 440 4-barrel engine will be built with either a forged or cast crankshaft. The cast crankshaft can be identified a different front vibration damper and a stamped letter "E" below the build date on the cylinder block identification pad."
