Re: '73 440 Motor with a Forged Crank?
[Re: 3_RTs]
#1720553
01/03/15 12:55 AM
01/03/15 12:55 AM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
I have one. Could this have come from a truck or motorhome? It has a harmonic balancer that is definitely not for a cast crank motor. The motor has not been taken apart, except that someone has taken the motor mounts and exhaust manifolds.
NO , the cast crank was phased in during the 73 model year , I had a non HP 440 -4 wit ha forged crank and LY rods.
[Re: vdriver]
#1720558
01/03/15 02:22 AM
01/03/15 02:22 AM
Posts: 10,559 Freeport IL USA
poorboy
Freeport IL USA
Chrysler had a tendency to use up what was laying around. If someone found a skid load of 440 cranks laying around in a warehouse someplace, they would have put them in the next batch of motors. Such was reportedly the case of the 6 pack crank and rods being used after the cast cranks were originally being installed. By the mid 70s, there weren't a lot of 440s being installed in anything. Chrysler would built motors bu batch loads, 440s this week, 400 next week and so on (time frames used as a reference only) Then as the specific motor was ordered, someone went and picked one up from the available batch (in simple terms) and it was installed. A batch of motors could have been built and sitting for a while before a new batch was run. This should get the BS flowing! Gene
[Re: 3_RTs]
#1720562
01/03/15 03:39 AM
01/03/15 03:39 AM
JohnRR
U.S.S.A.
The numbers on the top pad are J440 and 11 21. There's nothing else there.
73 440 assembled 11/21/72 , should have had a forged crank , nothing special or secert about it .
[Re: moparmarks]
#1720564
01/03/15 11:39 AM
01/03/15 11:39 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
All the '73's I have seen in the field had steel cranks, I have one under the bench now. That doesn't mean no cast cranks 440's were made in '73.
I might have just lucked out in my area.
"I think its got a hemi"
[Re: gdonovan]
#1720565
01/03/15 06:41 PM
01/03/15 06:41 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
All '73 440 HP motors got forged cranks, the STD 440 could have either cast or forged at random.
This is the subject of TSB 09-01-73C dated October 11, 1972: "The standard 440 4-barrel engine will be built with either a forged or cast crankshaft. The cast crankshaft can be identified a different front vibration damper and a stamped letter "E" below the build date on the cylinder block identification pad."
