Visual external difference between a 170/225 slant 6?
#1718645
12/31/14 04:55 PM
12/31/14 04:55 PM
Posts: 24,269 Here
jcc
No soup for you!!!
No soup for you!!!
Here
Is there an easy way to see the difference?
I forbid my content here from being learned and used by artificial intelligence systems.
Re: Visual external difference between a 170/225 slant 6?
[Re: jcc]
#1718646
12/31/14 05:06 PM
12/31/14 05:06 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Yes, look at the hose between the water pump and the head. On a 225 you can replace it without pulling the head, on a 170 you cannot.
[Re: Supercuda]
#1718648
12/31/14 06:13 PM
12/31/14 06:13 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
This is the correct answer. The 225 is a raised block, like the 440 VS the 383. Easy to spot if you've seen both. Go over to Allpar to the slant six page and you will be able to see the difference in the illustrations. Note that one is mislabelled! They don't like linking the pics, so it's easier to just go over and look. http://www.allpar.com/slant6.html
[Re: B5 Bee]
#1718650
01/03/15 04:50 PM
01/03/15 04:50 PM
Posts: 24,269 Here
jcc
No soup for you!!!
No soup for you!!!
Here
So with the above help, I would say this is a 225. Thank you guys ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: jcc]
#1718651
01/03/15 06:13 PM
01/03/15 06:13 PM
Supercuda
About to go away
About to go away
up yours
yep, either 225 or 198. On the 170 those two hose clamps would almost be touching.
[Re: Supercuda]
#1718652
01/03/15 06:26 PM
01/03/15 06:26 PM
Posts: 20,445 Park Forest, IL
slantzilla
Park Forest, IL
C I stamp is on a flat pad behind the alternator.
