Re: V-nose vs flat trailers
[Re: Jeepmon]
#1718601
01/01/15 11:31 PM
01/01/15 11:31 PM
Posts: 4,219 New York
polyspheric
New York
A "V" nose moves your tongue weight back slightly (unless you fill the V with buckshot). When it's really needed: when the tow vehicle's X-area at the hitch is much smaller than the trailer body (like an open pickup bed). Not as much help: behind an RV.
BTW: the sharp V is just easier and cheaper to build, the most streamlined shape is a small curved nose, with increasing radius (not a sharp angle) as it joins the flat sides.
Boffin Emeritus
[Re: Cab_Burge]
#1718603
01/02/15 08:10 PM
01/02/15 08:10 PM
Posts: 23,299 Here
jcc
Here
I see who I should have asked for pre marital advice. Now I know I believe the Flat and the v nose have nearly the same frontal area, it's the drag coefficient that is reduced. I also believe , and can't recall the exact reasoning for it, but the more efficient shape ( the v nose) is more prone to cross wind effects.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: jcc]
#1718604
01/02/15 08:28 PM
01/02/15 08:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I never had a wind issue with my V-nose trialer.. even with 35 mph winds... just had to watch the bridges for ice... LOL... that can and will catch your attention.... but I sold my trailer and sleds
[Re: MR_P_BODY]
#1718605
01/02/15 10:21 PM
01/02/15 10:21 PM
Posts: 23,299 Here
jcc
Here
The cross wind problem I'm thinking is there is slightly more frontal area exposed to the slight cross wind with a V nose, and that area can be further in front of the trailers cOG relative to a flat front, which induces greater sway. Obviously every towing combination will react differently.
[Re: jcc]
#1718606
01/02/15 11:11 PM
01/02/15 11:11 PM
MR_P_BODY
Yeah I always checked my COG the first time loading to make sure it had good tongue weight on all of my trailers... hell right now I own 11 trailers.. one for everything
