Re: motorcycle dyno [Re: Sport440] #171844
12/21/08 09:49 PM
12/21/08 09:49 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
i am glad you understand better!
i dont know if i can back in or not.stay tuned and see i guess.
i wish i had some dyno video pulls to post.i just got my camera last yr.
Thanks all!
ere is a test of my enine video.
http://www.youtube.com/watch?v=rvYjTkyqrmk
Re: motorcycle dyno [Re: blownzoom440] #171845
12/22/08 09:00 AM
12/22/08 09:00 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
good luck moving that beast. can you drain the fluid from the drum?
I put dozens of pulls on a dyno very similiar to that, but we dynoed my prostock snowmobile motors. We removed the drive clutch and bolt it directly to the shaft. We dynoed after every change and you can see from the expansion chambers alone there were many.
Re: motorcycle dyno [Re: MegaDart] #171846
12/22/08 07:24 PM
12/22/08 07:24 PM
ELYRIA,OH
ELYRIA,OH
sweet! i put the move off till saturday.i work friday. being a garbage man has no mercy.it was darn cold today too!
i thaught the drum was solid. 800+lbs
with those expansion chambers.have you herd of HMF.hanz muffler fabrication.
Re: motorcycle dyno [Re: blownzoom440] #171847
12/22/08 07:42 PM
12/22/08 07:42 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
no I've not heard of them. D&D was big into Arctic Cat pipes so was PSI, I also had a custom set made in Ontario by JAWS.
check into that drum, I almost remember my buddy talking about it h20 filled??
Re: motorcycle dyno [Re: MegaDart] #171848
12/22/08 08:16 PM
12/22/08 08:16 PM
ELYRIA,OH
ELYRIA,OH
i asked him and it is solid.
what would water do unless you wanted a bigger drum with same weight.[something like that ]
Re: motorcycle dyno [Re: blownzoom440] #171849
12/30/08 06:18 PM
12/30/08 06:18 PM
ELYRIA,OH
ELYRIA,OH
we got here moved using a U haul that is narower to get up to the lift and wench it on.it went smooth on and off we put a pipe under it and it just rolled off. here we are picking it up.
Re: motorcycle dyno [Re: blownzoom440] #171850
12/30/08 06:22 PM
12/30/08 06:22 PM
ELYRIA,OH
ELYRIA,OH
2
we kept the wenh attached to hold it from sliding back into the gate.
Re: motorcycle dyno [Re: blownzoom440] #171851
12/30/08 06:26 PM
12/30/08 06:26 PM
ELYRIA,OH
ELYRIA,OH
3
Re: motorcycle dyno [Re: blownzoom440] #171852
12/30/08 08:06 PM
12/30/08 08:06 PM
ELYRIA,OH
ELYRIA,OH
1 more detail.sorry!here is the wench i used to drag it on.it has a reducer wheel to 2X the pulling power by pulling half the distance with each stroke.
Re: motorcycle dyno [Re: blownzoom440] #171853
12/30/08 08:53 PM
12/30/08 08:53 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Good , you used my suggestion and got a different trailor. That saved you alot of headaches for sure. Congrats on the succesfull move.
How much was it to rent the Uhaul?? I see thier small trucks renting for 19.99 for a day. Whats a small trailor go for?? mikre
Re: motorcycle dyno [Re: Sport440] #171854
12/30/08 08:58 PM
12/30/08 08:58 PM
ELYRIA,OH
ELYRIA,OH
it was 26$ with tax per day.[5X9' trailer]it took 4 hrs to move it load/unloaded.ya we took our time.i have been trying to get this done for weeks but my brothers ADHD meds were not right. i didn't want to upset the universe.
