Re: Torsion Bar Removal
[Re: johnscudashop]
#1718099
01/02/15 06:05 PM
01/02/15 06:05 PM
Posts: 16,137 Mesa, Arizona
dart4forte
Mesa, Arizona
I been Making and selling these for years,with a 30 day replacement warranty. Knurled handle 1"X 1" solid steel striking surface .
I have one, it's slicker than snot.
[Re: DaveRS23]
#1718104
01/03/15 01:35 PM
01/03/15 01:35 PM
Posts: 4,713 Florida
BDW
I've always just used a couple of 1" rope clamps. Doesn't hurt the bars and gives a good surface for the hammer.
Tried looking for this, didn't see much, and what I did, couldn't see where you'd have some surface area to hit it? Got a link?
Here's a pic of a bike gooseneck that might work.
http://farm7.static.flickr.com/6194/6103662644_8b02a71d81_m.jpg
[Re: BDW]
#1718108
01/03/15 09:40 PM
01/03/15 09:40 PM
Posts: 12,037 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
http://static.grainger.com/rp/s/is/image/Grainger/4DV33_AS01?$zmmain$ $10 or so from Grainger. There is not a lot of hammering area, but they have always worked for me. Heck, I beat on the nuts as much as the clamps base. Doesn't seem to hurt them none. The pair I have are probably 40 years old and have pulled a good dozen sets of bars. As mentioned above, I loosen the lower control arm nut and pry the the lower control arm back and whack the clamps. Although it is probably not necessary, I clamp 2 clamps back to back against each other for more clamping force. One would likely be enough for most bars.
Master, again and still
