Torsion Bar Removal
#1718079
12/30/14 08:27 PM
12/30/14 08:27 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
How do you do it without a T Bar removal tool? I've heard you don't want to score the bars. Is there a nifty trick? Mine MAY just pop out because the car hasn't had weight on it since the whole front was rebuilt.
I’m listening.
Re: Torsion Bar Removal
[Re: Big Bad Bee]
#1718080
12/30/14 08:34 PM
12/30/14 08:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Spray them down good for a couple of days... give them a couple of hard whacks from the rear with a drift and BFH... then you should be able to slide them out
[Re: Cab_Burge]
#1718082
12/30/14 09:15 PM
12/30/14 09:15 PM
MR_P_BODY
Shocking them from the rear is just to break them free, they still have to come out the rear after the snap ring is removed EDIT I made up a 2" round alum block with the center bored thru the dia of the bars then slit it in half length wise .. drilled and tapped 2 holes and clamped it on the bar so I could hit the alum.. worked great
[Re: MR_P_BODY]
#1718084
12/30/14 10:05 PM
12/30/14 10:05 PM
Posts: 687 Ohio
Chad Bittle
Ohio
that's freakin' genius. I'll use that the day I have to do this job. I know the day is coming lol
[Re: Chad Bittle]
#1718085
12/30/14 10:25 PM
12/30/14 10:25 PM
Posts: 12,216 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I've always just used a couple of 1" rope clamps. Doesn't hurt the bars and gives a good surface for the hammer.
Master, again and still
[Re: Sixpak]
#1718093
12/31/14 12:21 AM
12/31/14 12:21 AM
Posts: 1,553 baldwinsville new york
a493demon
I usually pop the t bar clip, undo the LCA strut and the LCA pin nut, THEN I back off the torsion bar adjuster and use a pickle fork between the K frame and LCA and pry the LCA backwards. Never had one stuck yet. No special clamps or tools needed.
x2 but I just use a big pry bar.
[Re: Sixpak]
#1718094
12/31/14 12:39 AM
12/31/14 12:39 AM
Posts: 1,049 ohio
all spooled up
ohio
I DO THE SAME BUT USE A PRY BAR
[Re: Big Bad Bee]
#1718095
01/01/15 02:17 AM
01/01/15 02:17 AM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
As has been said, loosening the lca pin nut and knocking the pin free from the Kframe should unload any residual torsion from the bushing. The pickle fork works but so does any pry bar you can fit in there. You can back the nut off to the end of the pin and knock/pry the lca until the nut catches it if you need to, that's usually far enough to free the rear hex from the socket. Before I resort to that I usually just grab the stubborn bar just behind the lca socket, press on the socket with my thumb and whack on the bar with a soft mallet. It actually works a lot of the time. You may have to beat on it a while but you can feel the progress once it starts to move I've thought it would be nice if Chrysler had drilled/tapped a hole in the end of the bar so you could get ahold of it from behind with a slide hammer (or even claw hammer) and just pull on the thing. I've never tried drilling such a hole but I expect you'd need a carbide bit and perhaps a drill press. Even then, tapping might be impossible once the bar is heat treated. I took a bar to a heat treater for hardness testing and it measured at around Rockwell 45. That's over 200,000psi, closely matching a number I came up with based on vehicle weight and bar dimensions.
[Re: @#$%&*!]
#1718096
01/01/15 11:06 AM
01/01/15 11:06 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you have some scrap aluminum plate 3/8 or thicker laying around, two pieces about three by four inch with four holes drilled in them in about a 2x3 pattern will work. clamp the plates around the T bar so the long side is the place to hit, torque with an air wrench till the plates bend, hit with a BFH. No need for anything but removing the retaining ring. It might slide a bit on the T bar, so retorquing might be needed. this works on about any stuck T bar. The plates will twist on the T bar, but it helps them bite more.
