Re: Finally my 544 stroker 6 pak, can't wait .....
[Re: 70VcodeCoronetRT]
#1717356
12/29/14 07:51 PM
12/29/14 07:51 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
THANKS GUYS FOR KIND WORDS, SOME OF YOU KNOW THIS HAS BEEN A LONG TIME COMING. 440 block,steel 8 bolt crank,stroke 4.5,bore 4.35,roller hydraulic comp cam,duration intake 280,duration exhaust 288,lift intake 541 lift exhaust 537,harland sharp 1.5 rockers,6 pack jet,66 center, 80-86 outboards,matched to a john cope 727 with rmvb,billet drum,3500 to 3800 PTC converter, the goal was to have a health kick-ass street road runner, to be honest first motor I ever had really built, so when asked my combo, I share everything I can, yes the hick-up was outboards ,I still getting the final dyno runs on video. PK Machine in Fitchburg, built it and delivered Christmas eve. ![](/ubbthreads/images/graemlins/boogie.gif)
[Re: meepmeep70]
#1717357
12/29/14 08:03 PM
12/29/14 08:03 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
What heads?
[Re: meepmeep70]
#1717358
12/29/14 08:26 PM
12/29/14 08:26 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
you'll have to try different outboard springs to get it to open just right. I'm sure there's more in it. I run the purples and they seem to work well for me. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Mr.Yuck]
#1717360
12/29/14 08:36 PM
12/29/14 08:36 PM
meepmeep70
weymouth,mass.
you'll have to try different outboard springs to get it to open just right. I'm sure there's more in it. I run the purples and they seem to work well for me. [/quote using the white springs billet jet plates added after that pull with "holes drilled" next pull went much smother, still getting the videos just couldn't wait to share,5 pulls done filter cut inspected each time with dye added to oil to assure no leakage
[Re: meepmeep70]
#1717366
12/30/14 02:13 AM
12/30/14 02:13 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Nice!!
what RPM did it make peaks at?
torque 660 in by 4000 peak horse. 5800
That's a good 1800 rpm spread ![](/ubbthreads/images/graemlins/thumbs.gif)
At 660 torque @ 4000 rpm where looking at 503 HP. At your HP/RPM peak 5800, you are no doubt at 600+ HP ![](/ubbthreads/images/graemlins/bow.gif)
[Re: meepmeep70]
#1717367
12/30/14 03:19 AM
12/30/14 03:19 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
Moparts performance aluminum heads,
I sold Darren the heads that I had bought off another moparts member a number of years ago.
The heads are the MP 383/440 replacement heads, think a stage 6 but with a stock port location, not raised like a stage 6 so on a 440 it takes a 440 intake without a spacer.
The heads flow 290ish at .600, I don't know if the ports cross section will support 600hp ...
Well I guess it depends on how HAPPY the dyno throwing out a 600HP number is ...
[Re: JohnRR]
#1717369
12/30/14 11:43 AM
12/30/14 11:43 AM
meepmeep70
weymouth,mass.
How did you get that stroke to clear the internals of the factory block?!
External oiling?
Yes it has external oiling from the pictures I saw thata he sent me.
Thanks John, going to post so more pics later today thanks for all the nice words guys,a lot of you guys have helped me many times. ![](/ubbthreads/images/graemlins/bow.gif)
[Re: meepmeep70]
#1717370
12/30/14 12:28 PM
12/30/14 12:28 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Glad to hear you have it up and running. You are going to love it! I noticed that puff of smoke at the top of the center two cylinders. It might be caused by heat warping the header flange and allowing the top of the center tubes to leak. In the past to stop permanent warping of the header flange at the center, I had to weld bridges across both top and bottom of the flange.
