Need FSM 1971, 383 Magnum Cam specs #1717265
12/29/14 11:11 AM
12/29/14 11:11 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Does anyone have a FSM or any other "offical" oem specs on this cam ? I'm planning on running stock eliminator next yr with a 1970 383 challenger. According to NHRA,the cam specs are different on the 383 magnum from 70 to 71. I have the FSM for 70. What I have is below on cam lift. NHRA hp rating for these 2 engines are only 1 hp apart. So running my car as a 1971 may be a better choice, but I'd have to buy a grill/tail lights at roughly $1000. So I need to verify cam specs and make sure there isn't a typo in the nhra docs.
1970
FSM: lift = .450/.458
NHRA: lift = .455/.470
1971
FSM: lift = ?
NHRA: lift = .467/.483
thanks
Re: Need FSM 1971, 383 Magnum Cam specs [Re: varunner] #1717266
12/29/14 11:34 AM
12/29/14 11:34 AM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Hi. My 1971 Service Manual calls for .458" on the 383 Hi. Perf engine.
Garth
Re: Need FSM 1971, 383 Magnum Cam specs [Re: Big Wedge] #1717267
12/29/14 12:11 PM
12/29/14 12:11 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
You only need to concern yourself with what NHRA thinks it is. You need to access the NHRA Blueprint specs on the NHRA website. That is what the people you will be racing have done
Re: Need FSM 1971, 383 Magnum Cam specs [Re: Big Wedge] #1717268
12/29/14 12:44 PM
12/29/14 12:44 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Garth, Is that the lift on both intake and exhaust ?
Re: Need FSM 1971, 383 Magnum Cam specs [Re: scatpacktom] #1717269
12/29/14 12:49 PM
12/29/14 12:49 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
The numbers I already posted were directly from NHRA's site.... If there's a typo in their documentation, I want to let them know......if it's in my favor of course.......so to do that I need rock solid OEM numbers. I don't know what's better than the FSM.
Re: Need FSM 1971, 383 Magnum Cam specs [Re: varunner] #1717270
12/29/14 03:23 PM
12/29/14 03:23 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Sorry, my mistake. The intake lift is listed at .450" and the exhaust is listed at .458".
I scanned the 2 pages related to the camshaft for you.
Garth
Re: Need FSM 1971, 383 Magnum Cam specs [Re: varunner] #1717271
12/29/14 03:24 PM
12/29/14 03:24 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
I scanned the 2 pages related to the camshaft for you. This is the first.
Garth
Re: Need FSM 1971, 383 Magnum Cam specs [Re: Big Wedge] #1717272
12/29/14 03:26 PM
12/29/14 03:26 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
here is the second page
Garth
Re: Need FSM 1971, 383 Magnum Cam specs [Re: Big Wedge] #1717273
12/29/14 04:15 PM
12/29/14 04:15 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Garth,
Thanks for the scans. Pretty interesting actually. As most would have guessed, the FSM shows both 70 and 71 magnum cams having the same lift. NHRA shows the 71 with more lift........
Re: Need FSM 1971, 383 Magnum Cam specs [Re: varunner] #1717274
12/30/14 12:05 AM
12/30/14 12:05 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Best double check the pistons specs as well. I thought a 71 383 was low compression.
Sheldon
Re: Need FSM 1971, 383 Magnum Cam specs [Re: RUNCHARGER] #1717275
12/30/14 03:24 AM
12/30/14 03:24 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Sheldon
lower piston to deck height. 79.5 cc min chamber.
Re: Need FSM 1971, 383 Magnum Cam specs [Re: JohnRR] #1717276
12/30/14 12:15 PM
12/30/14 12:15 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
True. Less compression, but more room to play with the cam on the 71
