Page 2 of 3 1 2 3
Re: BB EFI, who has done it on a street/strip car? [Re: Jerry] #17160
08/23/05 12:43 PM
08/23/05 12:43 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I had the Ford system all laid out but never tried to install one. The trick piece was getting the distributor converted.
I shared the info quite some time ago with one of the guys here. He went through the install but I haven't heard from him in a little while.
With the effort and expense of gathering parts and doing the install, you might as well get a complete aftermarket system.
You're not really going to save any cash by piecing something together.
- Stu Harmon
Re: BB EFI, who has done it on a street/strip car? [Re: feets] #17161
08/23/05 02:10 PM
08/23/05 02:10 PM
I think I'm going with the Accel DFI system.
Re: BB EFI, who has done it on a street/strip car? #17162
08/23/05 02:34 PM
08/23/05 02:34 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
The EFI guy at Edelbrock said they are going to do a low deck Mopar "Pro Tuner" EFI setup next year.
Re: BB EFI, who has done it on a street/strip car? [Re: patrick] #17163
08/23/05 06:47 PM
08/23/05 06:47 PM
Itasca, Texas
Mad_Scientist Offline
Itasca, Texas
any kit thats worth while wether it be an inexpensive one or a high end one will only be relatively inexpensive if you aren't looking for HP. running about 500-550 HP will cost you no matter how you do it.
the edelbrock kits are okay if you can stay within their programmed parameters. But since you like changing things so much i would recommend either the megasquirt or accel DFI or FAST EFI. those kits allow future expandability that you really won't see with the edelbrock.
i'm in for about $1500 total on my megasquirt setup. the key is not rushing and finding the parts used or on ebay. once it comes to EFI all makes of parts are fair game so theres plenty of aftermarket available.
if you wanted to go a more "factory" route, you could look at adapting the GM 454 vortec EFI, or use a speed density tpi computer to run things....if you go TPI, buy your own chip burner.
I'd look at the holley commander 950 controller, too...they have a "universal" MPI kit for ~$1500...think you still need a fuel pump, mod the manifold, and injectors. for a distributor, use a lean burn 400 dist. running a GM HEI module, then the computer will control the timing.
I am working on the Holley Commander 950 setup right now. The pump is included, and there is no need to modify the manifold for a TB. Everything bolts up, and I am going to use a Rance distributor for my Hall effect with my MSD. This will allow me to control the timing from the computer. I can plug in, make my changes, then hit the road without ever popping the hood. You will need to run a second line for fuel/return line.
69 Super Bee 440 5-speed
70 Dart Swinger 340 4-speed
69 Camaro SS 396 4-speed
66 Cutlass Convertilbe
70 Judge Ram Air III 4-speed
68 F-100 SWB
Re: BB EFI, who has done it on a street/strip car? #17164
08/23/05 08:11 PM
08/23/05 08:11 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Big time wiring harness issues....just thought I would let you know.
Re: BB EFI, who has done it on a street/strip car? [Re: Mad_Scientist] #17165
08/23/05 08:25 PM
08/23/05 08:25 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
re: the commander 950
yep, if you go with the TBI setup, no manifold mod needed. for MPFI, you'll need to add injector bungs.
2017 Grand Cherokee Overland
Re: BB EFI, who has done it on a street/strip car? [Re: patrick] #17166
08/23/05 11:50 PM
08/23/05 11:50 PM
Explain this distributor. I have the Holley TBI kit, and I was looking for a way to have it utilize the ignition control.
Re: BB EFI, who has done it on a street/strip car? [Re: Dragula] #17167
08/24/05 12:01 AM
08/24/05 12:01 AM
Canada
CrAzYMoPaRGuY Offline
Canada
What "wiring harness issue" is THAT??!?!
Do you get paid to slag Accel or what?
CrAzYMoPaRGuY
Re: BB EFI, who has done it on a street/strip car? [Re: CrAzYMoPaRGuY] #17168
08/24/05 12:11 AM
08/24/05 12:11 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Re: BB EFI, who has done it on a street/strip car? [Re: FastmOp] #17169
08/24/05 12:30 AM
08/24/05 12:30 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: BB EFI, who has done it on a street/strip car? [Re: RichV] #17170
08/24/05 12:30 AM
08/24/05 12:30 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Have you thought about a set of stage VI heads?
Talk about a win-win... those have always been on my list of "must have" items when I do a low-deck stroker. If there was ever ANYTHING Ma Mopar got RIGHT, it was the decision to put the ports high enough to bolt up an RB manifold!
Clair
Re: BB EFI, who has done it on a street/strip car? [Re: Clair_Davis] #17171
08/24/05 01:22 AM
08/24/05 01:22 AM
I did the whole mustang conversion on a stroked sb. it worked pretty well, it had its limits but you can get those piggy backs like the tweecer that can change up the computer. It does very well on engines that are not extremely radical. just read the mustang sites to learn more about it. its very good for what it is but it is also old technology. i am doing another now with the accel gen 7, i dont see how it would have any wiring harness issues as it is for the most part contained within itself. We have done many of these with no problems. The ford conversion was quite expensive as i didnt use as much junk yard stuff as i could have used. it was also done having to gather all the parts needed. I dont like cutting corners on my builds. The dist. was a challange but ive got a great machine shop to work with and they fixed me up. Bottom line for me is to not cut corners because you will end up with inferior parts that end up not doing what you want them to do. Save up and do it right the first time.
Re: BB EFI, who has done it on a street/strip car? [Re: 71TA] #17172
08/24/05 03:29 AM
08/24/05 03:29 AM
Massachusetts
Faust Online content
Faust  Online Content
Massachusetts
Have a look at 034
I ran in to these guys when I was playing around with an old turbo Audi. They make 8 cylinder stuff now. Most important things are that the owner, Jahvad, won't go cold on you once you bought the stuff; and, there is a website for users: Motorgeeks.com.
Re: BB EFI, who has done it on a street/strip car? [Re: Faust] #17173
08/24/05 09:22 AM
08/24/05 09:22 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
like i've said a million times there are tons of megasquirt users out there and the message boards have all the fixes you will ever need. other than building it yourself its really simple to setup and use. and if you don't want to build it yourself there are plenty available on ebay that are certified to work and people even sell wiring harnesses for them
Re: BB EFI, who has done it on a street/strip car? [Re: Dragula] #17174
08/24/05 02:31 PM
08/24/05 02:31 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
HUH ?
Where in the world have you heard that?
The only...and I mean ONLY harness issues I`ve ever seen have been from people attempting to modify them and not have a clue what they are doing.
And i`ve done 1 or 2
Rick
Blown71X V2.0 under construction 71 Cuda 383 4-SPD (maybe for sale) 2010 Challenger B5 Classic
Re: BB EFI, who has done it on a street/strip car? [Re: Dragula] #17175
08/24/05 04:45 PM
08/24/05 04:45 PM
I'm pretty good with wiring and auto electronic so I'm not worried at all. In fact at some point I may try to run a 440 with a factory Magnum EFI controller, just for kicks.
Re: BB EFI, who has done it on a street/strip car? [Re: Blown71X] #17176
08/24/05 05:57 PM
08/24/05 05:57 PM
I love this thread I have been curious about both EFI and turbocharging for quite some time now, but have found very little info for 440 Mopars.
I am curious to hear what kind of performance gains you EFI users are making over your stock setup. I live at 8,000 feet and as you might imagine, a stock or near stock 440 doesn't make the same kind of power up here as it would at sea level. I want my Charger to stay fully streetable, but I definitely want more power.
I have considered a blower, but I don't want to cut my hood. Turbos fascinate me, but I am concerned about getting all the custom work done. I have thought about doing a stroker engine, but am concerned about streetability, longevity and cost.
Any advice on what might be the best bang for the buck? I am running 3:23 gears and would be pleased with a mid 13 to high 12 second car. Is EFI worth the investment?
Re: BB EFI, who has done it on a street/strip car? #17177
08/24/05 06:29 PM
08/24/05 06:29 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
EfI is worth the investment in terms of driveability and not performance gains. EFI and a carb should perform equally well. you should look into a centrifugal supercharger that way you don't have to cut the hood and don't have to worry about all the plumbing on turbos
Re: BB EFI, who has done it on a street/strip car? [Re: Jerry] #17178
08/24/05 06:40 PM
08/24/05 06:40 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Hey Jerry, bring us up to date on the Megasquirt. You said wait for version 3.0 or something. Whats the new version offer?
I'm interested and may work on this over the winter.
Re: BB EFI, who has done it on a street/strip car? [Re: 71TA] #17179
08/24/05 07:21 PM
08/24/05 07:21 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
Here are the megasquirt updates, you can use the version 2.2 or the version 3 boasrd but you definitely want to run MSII. MSI will work but there aren't as many features. mind you i've setup plenty of MSI boards and they all run fine and very successfully.
24 MHz HCS12 processor (C64 version),
Fuel control to 1 µsec (100 times more resolution than MegaSquirt),
Ignition control (full spark timing advance control, dwell control, etc) for one coil/distributor (7 pin HEI for example) and Ford's EDIS systems,
On-board stepper motor driver for IAC stepper control (this requires a few jumpers to be added on the MegaSquirt PCB to connect the socket jumpers to the DB37 connector),
Ford PWM idle valve support,
Built-in rev limiter, either 'fuel cut' or 'spark retard',
All tables are now 12×12 in size,
WBO2 AFR target table (in AFR units),
Independent dual-tables for VE and AFR target,
EGO feedback in wide-band mode is proportional to the difference between the measured AFR and the target AFR, the bigger the difference, the bigger the feedback step,
Spark advance table can have different rpm and kpa bins than VE and AFR tables,
115,200 baud serial interface with MegaTune2.25+,
CANbus networking for 'inter-board' communications with add-on modules like transmission controllers, sequential injection drivers, etc.,
Barometric correction amount and direction configurable in software, and provisions for:
barometric correction based on initial MAP reading,
independent 2nd barometric MAP sensor for continuous real-time baro correction, or
no baro correction.
TPS values for open loop and flood clear mode are user configurable,
MAP based open loop can be set as well as TPS,
Both TPS and MAP based accel enrichment is built into the code, you can configure the ratio of each,
Blended Alpha-N and speed density is an option,
2 spare I/O lines for custom controls. (This is in addition to 4 lines for Idle stepper control if you don't need this, or the Fast idle solenoid then becomes a spare if you do use a stepper motor.)
Page 2 of 3 1 2 3
