742 gear question! #1716219
12/27/14 03:05 AM
12/27/14 03:05 AM
Oak Harbor, WA
W
Wicked49670dart Offline OP
W
Oak Harbor, WA
Hey guys, I have a question on my 742 4.57 Richmond gears, have about 40 passes and about 50 street miles on them. When I installed them they had a little noise when loaded no noise coasting. Last time out street driving got on it pretty hard and while letting off of the gas had a bad howl while coasting and the same loaded. So pulled the gear out. Has a Richmond spool, so before I pulled the pass axles I rocked the axle back and fourth and there was 1/4" of a inch of backlash. Removed the pass axle, on the drivers side rocked the axle and now the backlash felt normal. Removed the gear and has .010 backlash now on the bench. Is it possible to have a pinion bearing issue causing the pinion to move that much under load? Can I reuse these gears again with them already making noise or start over with all new parts? Check to see if I could find any bearing play on the bench but everything is tight! Cap bolts and pinion nut are tight, Any ideas?
Thanks Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: 742 gear question! [Re: Wicked49670dart] #1716220
12/27/14 04:50 AM
12/27/14 04:50 AM
Three things to look at while it is apart, axle and spool splines, both sides, and cracks on the outer edges of the ring gear, coast and drive sides Look really closely after cleaning all the gear oil off of both sides If cracked replace them now before they break off during a run The howling indicates a change in the gear contact pattern to me BTW, which brand and type gears, street or Pro
Re: 742 gear question! [Re: Cab_Burge] #1716221
12/27/14 01:07 PM
12/27/14 01:07 PM
Oak Harbor, WA
W
W
Oak Harbor, WA
Thanks Cab, Richmond street gears and Richmond spool! One other thing I saw was the pinion seal was starting to leak also, was dry before with no movement in the pinion. Tells me the pinion under load was moving around? Thanks Matt
Re: 742 gear question! [Re: Wicked49670dart] #1716222
12/27/14 01:20 PM
12/27/14 01:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know what could be happening that you come
up with different back lash from side to side.. .010
is a little much.. if I recall... it should be .006
but not positive.. also every time I have noisey gears
from a previous set up they were always noisey(they
already have a wear pattern)... I use Richmond gears
in most everything(street gears)
Re: 742 gear question! [Re: MR_P_BODY] #1716223
12/27/14 01:34 PM
12/27/14 01:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been running Richmond street gears for 10+ years in a 742 case and they were noisy from the gate........... As far as the backlash.......... I think mine were at .006 right Cab?
Re: 742 gear question! [Re: Thumperdart] #1716224
12/27/14 02:07 PM
12/27/14 02:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What did the pattern look like to start? What does it look like now? What is the pinion preload rotating torque? How did you preload the spool bearings? .010" is a little high but not a killer. My bet is you've lost pinion preload, it didn't have enough to start , or the pinion depth was incorrect to start with. A torque wrench and the pattern will give the answer.
Doug
Re: 742 gear question! [Re: dvw] #1716225
12/27/14 08:11 PM
12/27/14 08:11 PM
Missouri
DC416 Offline
DC416  Offline
Missouri
Did it have a crush sleeve or a solid spacer? I had one and ripped it hard, started making noise and it had a crush sleeve in it. Replaced it with a crush sleeve eliminator kit and was fine.
Re: 742 gear question! [Re: DC416] #1716226
12/27/14 09:08 PM
12/27/14 09:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
742 has a stepped pinion , the crush sleeve is 489 only.
Re: 742 gear question! [Re: Wicked49670dart] #1716227
12/28/14 12:26 AM
12/28/14 12:26 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have seen this before when the shims were not de-burred before assembly Sometimes the pinion bearings don't seat fully and when the pinion finally does get a hard whoopin the pressure smashes the burrs.
Just my theory
Gus
64 Plymouth Savoy
Dana 60
Re: 742 gear question! [Re: fourgearsavoy] #1716228
12/28/14 03:04 AM
12/28/14 03:04 AM
Oak Harbor, WA
W
W
Oak Harbor, WA
Thanks guys for the help! Clean gear real good, checked all teeth and splines inside the spool. Everything looks O.K. Backlash is .010 checked in 3 spots and is what is etched on the Richmond ring gear. Preload is 10 pounds, gear pattern is definitely different. My problem that I'm still trying to figure out is, while rotating the pass axle clockwise (drive shaft disconnected)the axle rotated about 1" before the pinion yoke moved! Rotated counter clockwise 1" then the yoke moved again. Drivers side did not do this, rotated 1/4" before the yoke moved. Check the splines and the updated green bearing that Moser installed and all looks O.K. Again had a bad (loud) growling type noise when letting off the throttle from a hard full throttle launch! Thanks Matt
Re: 742 gear question! [Re: Wicked49670dart] #1716229
12/28/14 04:07 AM
12/28/14 04:07 AM
Try tightening up the left side carrier adjuster to see if you can get .006 backlash cold I have done that in the past on a OEM set of 4.56 on my old M.W. car when it starting getting loud, the backlash was upto around .015 and tightening it to .008 made the noise go away
Re: 742 gear question! [Re: Wicked49670dart] #1716230
12/28/14 11:28 AM
12/28/14 11:28 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Preload is 10 lbs or 10 inch lbs? pinion alone or pinion and ring together? What does "the pattern is different" mean?
Doug
Re: 742 gear question! [Re: Wicked49670dart] #1716231
12/28/14 01:04 PM
12/28/14 01:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you are turning an axle with a spool and you can turn it an inch before the yoke moves then something is very wrong on that side or the axle is made of rubber???
Re: 742 gear question! [Re: JohnRR] #1716232
12/28/14 01:12 PM
12/28/14 01:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The only thing I can think of for the different rotation
is the splines on the axle and maybe the spool are
worn on the one side.. more than the other side
Re: 742 gear question! [Re: MR_P_BODY] #1716233
12/28/14 07:01 PM
12/28/14 07:01 PM
Oak Harbor, WA
W
W
Oak Harbor, WA
Thanks guys, the pinion preload is inch pounds. The pattern now is inside edge on the drive side and outside on the heel side. Checked splines inside of the spool on the bench, all the splines look good. Measured inside diameter, both sides measure the same. Measured splines on the outside diameter of both axles, same size and measured at 3 different spots. Inserted both axles into the spool, both move the same when rotated back and forth. The ring and pinion pattern is already worn into the gear, so going to order all new gears and install kit with bearings so try this again. What brand of gears does everybody like to use? Motive, Richmond, or US gears? Thanks for all the help!
Re: 742 gear question! [Re: Wicked49670dart] #1716234
12/28/14 07:51 PM
12/28/14 07:51 PM
Rittman Ohio
Rittman Ohio
I like Motive gears Last couple of rears I've done with them the pattern was very nice.
Gus
64 Plymouth Savoy
Dana 60
Re: 742 gear question! [Re: Wicked49670dart] #1716235
12/28/14 08:12 PM
12/28/14 08:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most of the time I use Richmond but have used Motive
and Yukon.. I have a Yukon in my Rampage for the street/track
and Richmond in the race car(8 3/4 in the race car
and 9" in the Rampage.. 742 alum in the race car)
Re: 742 gear question! [Re: MR_P_BODY] #1716236
12/28/14 09:57 PM
12/28/14 09:57 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
backlash should be 8-12, most richmonds are noisy, not sure why yours got noisier though
Re: 742 gear question! [Re: upnover] #1716237
12/29/14 02:12 AM
12/29/14 02:12 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Read this completely.
http://www.yukongear.com/Downloads/Manuals/Yukon_General_Installation_Instructions.pdf
It will tell you more about patterns and set up than I had read in years in service manuals. This will get you a true pattern that works. Make sure you get the pinion depth set so that you have a proper pattern with the gear manufacturers suggested backlash. Do not try to adjust the pattern by putting the backlash beyond limits. Then pull it apart, shim the yoke for proper pinion bearing preload, 15-30"lbs. Install the ring gear and carrier. Set backlash to .000"-.001". Tighten the opposite adjuster until you are at your previous back lash that you had during the pattern check. This will give you your side bearing preload. If the patterns not correct, the pinion is at the wrong depth.
Doug
Re: 742 gear question! [Re: dvw] #1716238
12/29/14 03:51 AM
12/29/14 03:51 AM
Oak Harbor, WA
W
W
Oak Harbor, WA
Doug
Thanks for your help, a lot of good info there! Matt
