Re: 742 gear question!
[Re: Wicked49670dart]
#1716220
12/27/14 04:50 AM
12/27/14 04:50 AM
Posts: 43,293 Bend,OR USA
Cab_Burge
Three things to look at while it is apart, axle and spool splines, both sides, and cracks on the outer edges of the ring gear, coast and drive sides Look really closely after cleaning all the gear oil off of both sides If cracked replace them now before they break off during a run The howling indicates a change in the gear contact pattern to me BTW, which brand and type gears, street or Pro
[Re: Cab_Burge]
#1716221
12/27/14 01:07 PM
12/27/14 01:07 PM
Posts: 742 Oak Harbor, WA
Wicked49670dart
Oak Harbor, WA
Thanks Cab, Richmond street gears and Richmond spool! One other thing I saw was the pinion seal was starting to leak also, was dry before with no movement in the pinion. Tells me the pinion under load was moving around? Thanks Matt
#1716222
12/27/14 01:20 PM
12/27/14 01:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont know what could be happening that you come up with different back lash from side to side.. .010 is a little much.. if I recall... it should be .006 but not positive.. also every time I have noisey gears from a previous set up they were always noisey(they already have a wear pattern)... I use Richmond gears in most everything(street gears)
[Re: MR_P_BODY]
#1716223
12/27/14 01:34 PM
12/27/14 01:34 PM
Thumperdart
State of confusion
Been running Richmond street gears for 10+ years in a 742 case and they were noisy from the gate........... As far as the backlash.......... I think mine were at .006 right Cab?
[Re: DC416]
#1716226
12/27/14 09:08 PM
12/27/14 09:08 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Did it have a crush sleeve or a solid spacer? I had one and ripped it hard, started making noise and it had a crush sleeve in it. Replaced it with a crush sleeve eliminator kit and was fine.
742 has a stepped pinion , the crush sleeve is 489 only.
#1716227
12/28/14 12:26 AM
12/28/14 12:26 AM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have seen this before when the shims were not de-burred before assembly Sometimes the pinion bearings don't seat fully and when the pinion finally does get a hard whoopin the pressure smashes the burrs. Just my theory Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
#1716230
12/28/14 11:28 AM
12/28/14 11:28 AM
Posts: 9,873 MI, usa
dvw
MI, usa
Thanks guys for the help! Clean gear real good, checked all teeth and splines inside the spool. Everything looks O.K. Backlash is .010 checked in 3 spots and is what is etched on the Richmond ring gear. Preload is 10 pounds, gear pattern is definitely different. My problem that I'm still trying to figure out is, while rotating the pass axle clockwise (drive shaft disconnected)the axle rotated about 1" before the pinion yoke moved! Rotated counter clockwise 1" then the yoke moved again. Drivers side did not do this, rotated 1/4" before the yoke moved. Check the splines and the updated green bearing that Moser installed and all looks O.K. Again had a bad (loud) growling type noise when letting off the throttle from a hard full throttle launch! Thanks Matt
Preload is 10 lbs or 10 inch lbs? pinion alone or pinion and ring together? What does "the pattern is different" mean? Doug
#1716231
12/28/14 01:04 PM
12/28/14 01:04 PM
JohnRR
If you are turning an axle with a spool and you can turn it an inch before the yoke moves then something is very wrong on that side or the axle is made of rubber???
[Re: JohnRR]
#1716232
12/28/14 01:12 PM
12/28/14 01:12 PM
MR_P_BODY
The only thing I can think of for the different rotation is the splines on the axle and maybe the spool are worn on the one side.. more than the other side
[Re: MR_P_BODY]
#1716233
12/28/14 07:01 PM
12/28/14 07:01 PM
Wicked49670dart
Oak Harbor, WA
Thanks guys, the pinion preload is inch pounds. The pattern now is inside edge on the drive side and outside on the heel side. Checked splines inside of the spool on the bench, all the splines look good. Measured inside diameter, both sides measure the same. Measured splines on the outside diameter of both axles, same size and measured at 3 different spots. Inserted both axles into the spool, both move the same when rotated back and forth. The ring and pinion pattern is already worn into the gear, so going to order all new gears and install kit with bearings so try this again. What brand of gears does everybody like to use? Motive, Richmond, or US gears? Thanks for all the help!
#1716234
12/28/14 07:51 PM
12/28/14 07:51 PM
fourgearsavoy
Rittman Ohio
I like Motive gears Last couple of rears I've done with them the pattern was very nice. Gus
#1716235
12/28/14 08:12 PM
12/28/14 08:12 PM
MR_P_BODY
Most of the time I use Richmond but have used Motive and Yukon.. I have a Yukon in my Rampage for the street/track and Richmond in the race car(8 3/4 in the race car and 9" in the Rampage.. 742 alum in the race car)
[Re: upnover]
#1716237
12/29/14 02:12 AM
12/29/14 02:12 AM
dvw
MI, usa
Read this completely. http://www.yukongear.com/Downloads/Manuals/Yukon_General_Installation_Instructions.pdf It will tell you more about patterns and set up than I had read in years in service manuals. This will get you a true pattern that works. Make sure you get the pinion depth set so that you have a proper pattern with the gear manufacturers suggested backlash. Do not try to adjust the pattern by putting the backlash beyond limits. Then pull it apart, shim the yoke for proper pinion bearing preload, 15-30"lbs. Install the ring gear and carrier. Set backlash to .000"-.001". Tighten the opposite adjuster until you are at your previous back lash that you had during the pattern check. This will give you your side bearing preload. If the patterns not correct, the pinion is at the wrong depth. Doug
[Re: dvw]
#1716238
12/29/14 03:51 AM
12/29/14 03:51 AM
Wicked49670dart
Oak Harbor, WA
Thanks for your help, a lot of good info there! Matt
