Page 3 of 3 1 2 3
Re: racing oil [Re: Quicktree] #1715891
12/29/14 08:42 PM
12/29/14 08:42 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
Blatantly plagiarized from Wikipedia:
"The Society of Automotive Engineers (SAE) has established a numerical code system for grading motor oils according to their viscosity characteristics. SAE viscosity gradings include the following, from low to high viscosity: 0, 5, 10, 15, 20, 25, 30, 40, 50 or 60. The numbers 0, 5, 10, 15 and 25 are suffixed with the letter W, designating they are "winter" (not "weight") or cold-start viscosity, at lower temperature. The number 20 comes with or without a W, depending on whether it is being used to denote a cold or hot viscosity grade. The document SAE J300 defines the viscometrics related to these grades."
not accusing you of anything but trying to make a simple thin more complex than it needs to be, ok we get it you are a very smart guy. a lot smarter than us who call it weight. but guess what, we don't care and have fun with your science.
May be a dumb question..
Why Mobil 1 Racing have 0W-30 and 0w-50 normally if 0W are for winter why use it in racing engine,most racing car are use during warm weather...
Re: racing oil [Re: STROKIE] #1715892
12/29/14 10:16 PM
12/29/14 10:16 PM
Some oils just hate alky--they look bad quick
Brad Penn does very well with alky and is most alky users first choice
The new Kendal GT1--I may be wrong I think it is Conoco from Texas now--seems to do well with alky and is pretty cheap at around $35 case range--I have been buying it from wholesaler, running in alky injected and it is doing good so far
I like the Penn but the price is just too high for as much as I go through--
I have no doubt Walmart oil would do OK too--this is just one of those topics that no matter what--folks are not going to agree on anything about it.
I like learning but that guy lost me when he said he believed things David Vizard said--
Re: racing oil [Re: ] #1715893
12/29/14 10:31 PM
12/29/14 10:31 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I always ran Mobil 1 15w50 red cap in my BB flat tappet engine for 19 years. My Gen III will probably get Mobil 1 0W40 because of the tight bearing clearances and oil squirters. I also believe that the way the oil returns to the pan on these things a lighter oil is needed.
Mopar to the bone!!!
Re: racing oil [Re: 72Swinger] #1715894
12/29/14 10:35 PM
12/29/14 10:35 PM
Queensland
N
NOM36 Offline
NOM36  Offline
N
Queensland
I would like to see what people think about oils and alcohol.
Seems like there is a debate about dilution and non-diluted.
Re: racing oil [Re: NOM36] #1715895
12/29/14 11:34 PM
12/29/14 11:34 PM
warren, mich.
dwayne welder Offline
warren, mich.
HI ALL!!!!! Happy Holidays Here's a good web site to go and learn a lot about oil!!!!! www.BOBISTHEOILGUY.COM Enjoy and have fun!!!!
Re: racing oil [Re: NOM36] #1715896
12/30/14 06:44 AM
12/30/14 06:44 AM
Q
Quicktree Offline
Quicktree  Offline
Q
depends on how the car is tuned imo. I have run alky injected and carb. if it's rich it will dilute any oil if it's tuned you can't tell the difference between gas.
Re: racing oil [Re: ] #1715897
12/30/14 09:20 AM
12/30/14 09:20 AM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
I heard Red Line does well with alcohol. Any truth to that?
It seems it was a bit cheaper than the Penn oil too. But that's been a little bit.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: racing oil [Re: 1320Dart] #1715898
12/30/14 12:17 PM
12/30/14 12:17 PM
gregsdart Offline
gregsdart  Offline
20w50 Brad Penn suits my race motor because I run it hot with fairly large clearances of .003 rods and .0035 mains plus high temps. I warm the motor past 210 for the start of the day and the oil temp goes over 200. I stage at 185 and the oil temp is still above 200 at the line. Injectors are VERY fat at idle but the heat boils off the alky that gets in the oil because Methanol boils at 149 degrees. Water boils out as well with no problems or milking ever.
Re: racing oil [Re: 340B5] #1715899
12/30/14 07:24 PM
12/30/14 07:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A true synthetic is slick enough that the lifters can quit rotating.
Some myths never die.
http://www.drivenracingoil.com/news/dro/...ve-the-answers/
Re: racing oil [Re: John_Kunkel] #1715900
12/30/14 10:44 PM
12/30/14 10:44 PM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
VR-1 10w30 has been in my 408 since 2009 and I had it apart last year and it was in great shape.Didn't need to change the bearings but I did anyway. No reason for me to go to another brand of oil.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: racing oil [Re: 77DragracerR/T] #1715901
12/31/14 11:52 AM
12/31/14 11:52 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I ran 15w50 Mobil1 for years with a flat tappet and I think the cam is about the only thing I've never broke.. Now since I put the motor back in I am running Brad Penn 10w30 and so far I really like the stuff.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: racing oil [Re: 77DragracerR/T] #1715902
12/31/14 01:31 PM
12/31/14 01:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
As good as that oil is, I think you should change it cos that`s a LONG time w/out an oil change............
Re: racing oil [Re: John_Kunkel] #1715903
12/31/14 03:14 PM
12/31/14 03:14 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Myth or not, I've had 2 well respected Automotive machinists tell me otherwise. I'm sticking w/Brad Penn.
Yeah, it's got a smallblock.
Re: racing oil [Re: 340B5] #1715904
01/01/15 06:33 AM
01/01/15 06:33 AM
Ohio, United States
BuckeyeBrawler Offline
Ohio, United States
I've always ran Brad Penn 20/50 bearings always have looked good at tear downs, religiously warm motor and driveline by motoring around pits. Water temp to 200-210 then let it cool to 140. I use a block heater even during the summer unless really hot Ohio weather and try and pull into burn out box @ 180 water temp. Aluminum rods live and bearings look good. there may be something better out there, but she's not hurting parts so I'm not changing a thing.
Re: racing oil [Re: BuckeyeBrawler] #1715905
01/01/15 06:42 AM
01/01/15 06:42 AM
Ohio, United States
Ohio, United States
Sorry guys forgot to mention also run a Moroso accumulator so I never start the motor dry flip the toggle switch wait a 20 to 30 seconds and light her it up. Never start it dry and also some added protection for the big wheel stands that I hate, not to mention it helps at the shutdown area as well. Cheap insurance IMO
Re: racing oil [Re: BuckeyeBrawler] #1715906
01/01/15 02:38 PM
01/01/15 02:38 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Brad Penn is a semi synthetic...use it...and never look back. The results are what the are. It works.
As an FYI side,on the alcohol we run BP70W in the blown alky cars, best stuff yet.
RIP Monte Smith
Re: racing oil [Re: CompWedgeEngines] #1715907
01/01/15 03:38 PM
01/01/15 03:38 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I used to run 5-50 synthetic, Mobile 1, Castrol, etc. Been using Brad Penn semi synthetic 10-30 after break in, the last couple of years. I also run a 3 quart accumulator, .003 rods, .0035 mains, with no issues from oil. I like it. I'm at 80+#'s through the lights at 8000 RPM, oil temp at 140-160. I couldn't care less about water temp at the starting line unless it's overheating. I also have a pan heater and won't make a pass until oil temp is 120. BTW viscosity is measured in centapoise@70 degrees F(cps), not weight. It doesn't matter to me what you want to call it, but that is right.
Re: racing oil [Re: CompWedgeEngines] #1715908
01/01/15 03:54 PM
01/01/15 03:54 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
What would you use in a carbureted alcohol motor?
Greg
Re: racing oil [Re: 1320Dart] #1715909
01/06/15 02:19 AM
01/06/15 02:19 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
Brad Penn 10w-30 is what I run in my 572 on Alky and I run the same oil now with my 582 on no2 and nitrous. Brad Penn 10w-30
Page 3 of 3 1 2 3
