Page 5 of 10 1 2 3 4 5 6 7 9 10
Re: Air filters on race cars?? [Re: MR_P_BODY] #1715145
12/29/14 03:42 AM
12/29/14 03:42 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
it's a 4" Mr P. i have a 3" K&N but it's MIA in the garage somewhere. i wanted to give that a clean too & compare but i only have (had?) the round element part.
Re: Air filters on race cars?? [Re: rebel] #1715146
12/29/14 03:55 AM
12/29/14 03:55 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I know just putting the 3" filter and lid on my car, it gets rich and the idle drops just a tad so what`s it doin past 7000 r`s? I`d be curious on that test............
Re: Air filters on race cars?? [Re: Thumperdart] #1715147
12/29/14 04:05 AM
12/29/14 04:05 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
I'm leaning towards the uni filter as it's shape will be perfect for my hood. I always ran with out a filter because i felt a difference in my 93 dakota when racing with filter on or off. Also the truck pulled more rpm than it would with the filter on. But I'm pretty sure the stock hood played a major role in that the filter was most likely against the hood reducing air flow.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Air filters on race cars?? [Re: rebel] #1715148
12/29/14 11:36 AM
12/29/14 11:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I ran a 3" K&N... I was curious why you got different
number.. I also forgot what flow I did this at but I
believe it was a fair bit higher... wish I still had
my paper work
Re: Air filters on race cars?? [Re: mopar65] #1715149
12/30/14 12:43 PM
12/30/14 12:43 PM
gregsdart Offline
gregsdart  Offline
I need to find a set up for my tunnel ram that will fit under a 7 inch tall hood scoop.
If you go to K&Ns web site they have many different shapes of filters. You may have to get creative to build the base, but lids are easy to make out of aluminum plate should you need every last bit of room. For my race motor with a Dominater flange I used a drop base attached to an air pan combined with a 14x6 and a flat lid to get it under my scoop.
Re: Air filters on race cars?? [Re: gregsdart] #1715150
12/30/14 12:51 PM
12/30/14 12:51 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Is there a better shape of filter to strive for? I've read many many many articles on this. Just curious to here my Moparts guys on this....
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Air filters on race cars?? [Re: 1320Dart] #1715151
12/30/14 01:33 PM
12/30/14 01:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
DO TELL....................
Re: Air filters on race cars?? [Re: DemonDust] #1715152
12/30/14 01:50 PM
12/30/14 01:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
After reading the Wix flow #`s compared to the K&N`s, I think for now I`ll lower my sealed base and run a 4" w/no lid squeezed againtsed the scoop till I figure out the scoop deal. The K&N I run they say flows in the 700`s where the Wix racing is 1000+ so I`ll start there..........
Re: Air filters on race cars?? [Re: Thumperdart] #1715153
12/30/14 02:06 PM
12/30/14 02:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have to use a spacer for the air cleaner to clear
the linkage and yesterday I seen that the front of
the 14" dia filter hits the hood and holds it up a
little... I'm gonna try angle cutting the spacer to
see if that will clear... I dont want to go any shorter
than the 3" filter that I am using... this is on my
throttle body.. but it was about the same on the 850
carb.. but that was a bit lower(no spacer)
EDIT
Plus I'm dumping the K&N that was a gift to me..
but I need the flow
Re: Air filters on race cars?? [Re: MR_P_BODY] #1715154
12/30/14 02:18 PM
12/30/14 02:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m in the same boat Mike so I`ll adjust that too. You really should look into the Wix racing filters.........
Re: Air filters on race cars?? [Re: Thumperdart] #1715155
12/30/14 02:39 PM
12/30/14 02:39 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I had been running a cheap 14x3 auto parts store filter for the past few years..... Just installed a new WIX Racing filter. My setup is a RamAirBox breathing through the grille. Wish I could fit a taller filter, but 3" with a drop base has me right against the hood.
Re: Air filters on race cars?? [Re: StealthWedge67] #1715156
12/30/14 02:41 PM
12/30/14 02:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So can you see/feel a difference? Do u have a wide-band?
Re: Air filters on race cars?? [Re: Thumperdart] #1715157
12/30/14 02:47 PM
12/30/14 02:47 PM
Puyallup, WA
Puyallup, WA
Litrally just recieved it from Summit yesterday and istalled in last night. Doubt I'll FEEL any difference, but I'll be watching the timeslip! No, I don't have a wideband. It's on my priority list, though; Might even get one this winter (???).
Re: Air filters on race cars?? [Re: StealthWedge67] #1715158
12/30/14 03:20 PM
12/30/14 03:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Re: Air filters on race cars?? [Re: StealthWedge67] #1715159
12/30/14 03:30 PM
12/30/14 03:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I really like those Ram type boxes with the hoses..
I'm trying to set something up like that with my cowl
hood
Re: Air filters on race cars?? *DELETED* [Re: gregsdart] #1715160
12/30/14 04:29 PM
12/30/14 04:29 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Post deleted by mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Air filters on race cars?? [Re: MR_P_BODY] #1715161
12/31/14 12:22 AM
12/31/14 12:22 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
My RW dyno results with a single carb on the
Modman
Carb was a 800cfm AVS THUNDER
KN 14x3 with Xtreme lid - 318 RWHP
MOROSO 16x3 - same day - 333 RWHP
No air cleaner - 277 RWHP
KN Hemi dual quad 2" high - twin AFB 500s - 358 RWHP
Two lessons Ive learned over time...
1 - Carters hate being run without an air bell or cleaner.
2 - Xtreme lids rob HP compared to a decent size normal filter element. Joe Sherman has made similar findings on Speed Torque.
Re: Air filters on race cars?? [Re: Moparmal] #1715162
12/31/14 12:37 AM
12/31/14 12:37 AM
Moparmal Offline
Moparmal  Offline
FWIW - using the KN formula..the following applies...
A 408 spinning to 6500rpm requires 127sq" of filter surace area.
The formula is (rpmxcui) / 20,839.
Using a circle calculator - circumferance x height.
the following cam be calculated....
Your 14x3 cleaner without xtreme lid offers 131.94 sq" of surface area
A 9x5 offers 141.35 sq"
and an 8x9 provides 226 sq" of filter area.
Re: Air filters on race cars?? [Re: mopar65] #1715163
12/31/14 12:51 AM
12/31/14 12:51 AM
Moparmal Offline
Moparmal  Offline
thanks for the info. I was thinking about trying to use a air filter that is used with the six pack set up? think it would flow more air than 2 9 inch air filters? I have 2 K&N 9 inch air filters but they are 8 inches tall by them self. if i had a shop etc i8 would just run the carbs through the hood with the 8 inch tall filters.
No way no how..
A 2" high oval 6 pack filter had 121sq" of filter area. (60.75 citcumference x 2" height.)
Two 9x8s = 226.16sq" x 2 = 452sq" !!!!
Re: Air filters on race cars?? [Re: Moparmal] #1715164
12/31/14 02:42 AM
12/31/14 02:42 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Modman
Good info thankxxx.............So my 14x3 has been killin me from day one and the K&N site sez the 14x3 flows under 700 cfm and the Wix racing 4" flows 1000+ so that`s my next purchace. My s$%^z gonna fly next time out..........
