Re: Air filters on race cars??
[Re: sr4440]
#1715085
12/25/14 01:28 PM
12/25/14 01:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
When we were designing air filters and housing we designed them for the max power... ALL filters are a restriction but we had to use that to our benefit.. I prefer to have the filter element as a remote and plumb the air in with a nice radiused inlet to the carb or throttle body to straighten the air out ![](/ubbthreads/images/graemlins/wave.gif)
[Re: radar]
#1715087
12/25/14 01:34 PM
12/25/14 01:34 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I remember a few years ago this came up and everybody was talking about how they use one of those filters that looks like a flat box with a wedge in the front all the air came in the top/front. Don't remember the name. I remember looking them up since I was looking for a better option under my 340 scoop. Too much $$ for my street effort.
Uni-Filter, they are expensive.....
http://www.hoffpro.com/category_s/95.htm
[Re: ProSport]
#1715088
12/25/14 01:42 PM
12/25/14 01:42 PM
ProSport
Akron, Ohio
If my car ever makes it to a track I will probably use a screen from Intensity, it will at least keep rocks and birds out. I can only fit a 10x2.75 air cleaner on my car and there's no way it will feed a 500" engine at WOT. Speaker covers work also, as Sixpackgut mentioned. I had a 340 Scamp years ago that ran great with a 14x5 K&N but my big block cars have always slowed down with an air cleaner so I ran for many years without one. http://intensityracingproducts.com/proseriesscreens.html
[Re: J_BODY]
#1715091
12/25/14 01:54 PM
12/25/14 01:54 PM
MR_P_BODY
UNI filter worked well with our cowl hood on our W5 mill.... unfortunately this set up came in at .75" too high, so the 4150 carb is on for the time being. I never ran a filter on the Mirada. Dang top of the carb was up in the Dart Sport hood scoop I was running.... no room.
....and yes, these are basically "bug and rock" catchers imho, kind of like the K&N filters I see in so many diesel trucks.... with blowby.
The Uni you show here.. how tall is it... I have to find something(or build) to fit under my cowl hood.. with a 4150 I can fit a 14 X 3" but with the new throttle body it sits taller... plus I have to have a spacer to clear the linkage ![](/ubbthreads/images/graemlins/wave.gif)
[Re: J_BODY]
#1715094
12/25/14 02:06 PM
12/25/14 02:06 PM
MR_P_BODY
From the measurements it looks like I might be making something... but I'll make my final measurements today when I can close the hood(still working under there so I have to clear some stuff out of the way) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: J_BODY]
#1715099
12/25/14 02:51 PM
12/25/14 02:51 PM
Posts: 7,506 Az
Crizila
Az
Haven't tried running without it yet. Any debris in there could be expensive. I believe Procharger recommends a filter.
Fastest 300
[Re: Crizila]
#1715100
12/25/14 03:08 PM
12/25/14 03:08 PM
MR_P_BODY
I think I'll do like Doug did and make a base for the Uni... but I need to make a plate to seal in the cowl so I'll see what I can come up with.. first I need to get the injection running... see if I can down load the basic program today if I get the chance ![](/ubbthreads/images/graemlins/wave.gif)
[Re: WheelsUp73]
#1715102
12/25/14 05:47 PM
12/25/14 05:47 PM
MR_P_BODY
I run a 14 x 3 filter in a Ram Air Box. I picked up .2 in the qtr and 4 mph with this setup vs an open carb unfiltered with no hoodscoop.
It should since you were putting some pressure to the intake with that set up ![](/ubbthreads/images/graemlins/wave.gif)
