Drawing for Hemi & B/RB oil pan rail? #1714558
12/23/14 04:50 AM
12/23/14 04:50 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
Has anyone got a drawing for the oil pan bolt pattern on a Big Block Chrysler. I would check my Mopar engines book, but it's in storage
Thanks in advance!
Alan Jones
Re: Drawing for Hemi & B/RB oil pan rail? [Re: LA360] #1714559
12/23/14 04:10 PM
12/23/14 04:10 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
How about a DXF file that would be even better !!
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Drawing for Hemi & B/RB oil pan rail? [Re: LA360] #1714560
12/23/14 08:06 PM
12/23/14 08:06 PM
AndyF Offline
AndyF  Offline
I've never seen anyone publish that drawing. It isn't in any of the Mopar books. I don't know where the oil pan guys got their dimensions, maybe reverse engineering? That could explain why some oil pans don't fit very well.
Re: Drawing for Hemi & B/RB oil pan rail? [Re: go green] #1714561
12/23/14 10:12 PM
12/23/14 10:12 PM
LA360 Offline OP
LA360  Offline OP
I have been sent one by a friend in Sweden (Thanks Tom!)but the file was corrupt. I will try again and if it works out, I will check out that it fits, and I will then send out something to you Go Green. PM me your email address.
Alan Jones
Re: Drawing for Hemi & B/RB oil pan rail? [Re: LA360] #1714562
12/23/14 10:27 PM
12/23/14 10:27 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have to check I might have one....Unfortunately, I do not have Solid Works on my home computer..
Re: Drawing for Hemi & B/RB oil pan rail? [Re: Dragula] #1714563
12/24/14 07:33 AM
12/24/14 07:33 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
here is the drawing that I sent to Alan.
I also sent an DWG and DXF also.
I got the PDF drawing from a Moparts member, donīt know where it comes from.
The two bolt holes in front and the two at the back didnīt line up when I made an paper copy and tested on my Megablock, so check those out.
8372123-PanDimemsions.pdf (288 downloads)
Re: Drawing for Hemi & B/RB oil pan rail? [Re: RT540] #1714564
12/24/14 10:27 AM
12/24/14 10:27 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Probably make sense. Not dimensioned as they are not drilled and tapped in this process step. Just guessing.
Nice info though, thanks.
Re: Drawing for Hemi & B/RB oil pan rail? [Re: RT540] #1714565
12/24/14 02:20 PM
12/24/14 02:20 PM
NC
440Jim Offline
440Jim  Offline
NC
I did some quick measurements on a 1977 block and they were within about 0.015" of that drawing. I didn't make an oil pan, but a jig that mounted to the various holes and it fit well between any pair of holes. For example:
Drawing Mine
4.200 4.187 between the holes (large spacing)4-3/16
2.700 2.687 between the holes (small spacing)2-11/16
2.740 2.756 between the holes (ends) ~2-3/4 = 2.750
0.580 0.580 side offset rear holes ~37/64 = 0.578"
I didn't use the front holes, but I just went in the garage and made a quick side offset measurement and 0.460 looks like it matches that drawing (1.140-0.680=0.460). When adding up the spaces, the drawings 4.20 and 2.70 fit better then the fractions I used.
Re: Drawing for Hemi & B/RB oil pan rail? [Re: 440Jim] #1714566
12/24/14 08:17 PM
12/24/14 08:17 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I have access to a laser scanner at work - would a cad file of the pan rail help? I can get one but it might take a week or so.
