Re: Small Block Stroker question part 2
[Re: dustyswinger]
#1713286
12/20/14 11:04 PM
12/20/14 11:04 PM
Posts: 1,532 off the grid
340B5
off the grid
Your best bet is to call a good cam company like Bullet or Racer Brown and let them recommend one. Myself (if it for a 4"stroke)I don't think either cams mentioned is right.
Yeah, it's got a smallblock.
[Re: pittsburghracer]
#1713289
12/21/14 01:58 AM
12/21/14 01:58 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
Let me get this right. The engine made 621 HP on a dyno BUT you only want 585 HP. Don't be surprised if the 621 DYNO HP ends up acting like 585 hp when it hits the track. Fantasy dyno numbers usually never end up panning out on the track. Give it a try.
That isn't one of the fantasy dynos. Seen more than enough 600+hp engines from others in 3000# cars running 11.00 at 120... LOL
568 at 3350 10.52 570 at 3200 10.36 529 at 3300 10.68 485 at 3350 6.93 in 1/8
All at better than 124-125 (except the 1/8 mile one)
If the op wants less hp, put less compression and cam in it.
#1713291
12/21/14 02:18 AM
12/21/14 02:18 AM
RobX4406
You are talking about 35 HP. put the thing together and race it. Didn't read the article but did it have a set of dyno headers on it and the same carb? Corrected HP?????
Most of those were with a set of tti or hooker 5204's and a 950 hp. Same as what was installed in the car. That dyno isn't the infamous westech lottery machine.
Cars ran those numbers. Are those not good et's for that HP... they sure are and the MPH was right in line.
[Re: RobX4406]
#1713292
12/21/14 02:27 AM
12/21/14 02:27 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I just dont understand the OP reason to drop 35hp.. if he wants to.. put a smaller carb on it.. the engine was/is a proven piece
[Re: dustyswinger]
#1713294
12/21/14 02:59 AM
12/21/14 02:59 AM
MR_P_BODY
I put a 641 HP motor in my car and it went 9.84 at 136 and put the car on the rear bumper leaving from 2000 rpm on a 9 in slick so I'm not looking to do that again. With 500 HP or went 10.43 so I figured 585 would get me low tens without the chance of wrecking the car.
Retard the cam some so you loose some torque and a smaller carb.. and you can pull timing
[Re: dustyswinger]
#1713295
12/21/14 03:00 AM
12/21/14 03:00 AM
RobX4406
{sarcasm}How ignorant and foolish of you to have a plan.{/sarcasm}
LOL
[Re: RobX4406]
#1713296
12/21/14 03:03 AM
12/21/14 03:03 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Switch out the 1.65 rockers for a set of 1.5's
[Re: dustyswinger]
#1713300
12/21/14 07:54 AM
12/21/14 07:54 AM
Quicktree
fix the dang chassis, dropping a few HP is not going to help. 585HP can do the same thing
[Re: B3422W5]
#1713302
12/21/14 01:25 PM
12/21/14 01:25 PM
WHY ask us??? Ask the guy that built it--he knows what is best for that engine period.
