Small Block Stroker question part 2 #1713284
12/20/14 09:17 PM
12/20/14 09:17 PM
MN
dustyswinger Offline OP
MN
I am ordering a BPE crank and some scat H beams. thanks for the help. I am asking about the cam now. As I said I`m looking for 585 HP. I have the top end off of IMM machine`s 621HP motor that was in Hot Rod. The cam, valve train, heads and intake. I have a 950 holley carb and 1 7\8 hedman hedders. I am not looking for all out power. The cam is 260\266 at .050 with .683/.653 lift and 112 centerline. The other cam I`m looking at is 248\252 and with the 1.65 ratio rocker arms it turns out to .630 lift with a 110 centerline. I don`t know alot about cams but think it would be a better cam for me. What do you guys thnk. Thanks again. Craig
Re: Small Block Stroker question part 2 [Re: dustyswinger] #1713285
12/20/14 11:01 PM
12/20/14 11:01 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
best guys to ask is IMM
Re: Small Block Stroker question part 2 [Re: dustyswinger] #1713286
12/20/14 11:04 PM
12/20/14 11:04 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Your best bet is to call a good cam company like Bullet or Racer Brown and let them recommend one. Myself (if it for a 4"stroke)I don't think either cams mentioned is right.
Yeah, it's got a smallblock.
Re: Small Block Stroker question part 2 [Re: 340B5] #1713287
12/21/14 01:31 AM
12/21/14 01:31 AM
MN
MN
The bigger can is the one that came with the parts of the 621 hp motor from Brian. I'm not looking for that much power, just wondering if the smaller cam would get me where I want to be.
Re: Small Block Stroker question part 2 [Re: dustyswinger] #1713288
12/21/14 01:41 AM
12/21/14 01:41 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Let me get this right. The engine made 621 HP on a dyno BUT you only want 585 HP. Don't be surprised if the 621 DYNO HP ends up acting like 585 hp when it hits the track. Fantasy dyno numbers usually never end up panning out on the track. Give it a try.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small Block Stroker question part 2 [Re: pittsburghracer] #1713289
12/21/14 01:58 AM
12/21/14 01:58 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
That isn't one of the fantasy dynos. Seen more than enough 600+hp engines from others in 3000# cars running 11.00 at 120... LOL
568 at 3350 10.52
570 at 3200 10.36
529 at 3300 10.68
485 at 3350 6.93 in 1/8
All at better than 124-125 (except the 1/8 mile one)
If the op wants less hp, put less compression and cam in it.
Re: Small Block Stroker question part 2 [Re: RobX4406] #1713290
12/21/14 02:13 AM
12/21/14 02:13 AM
PA.
"Little"John
"Little"John
PA.
568 at 3350 10.52
570 at 3200 10.36
529 at 3300 10.68
You are talking about 35 HP. put the thing together and race it. Didn't read the article but did it have a set of dyno headers on it and the same carb? Corrected HP?????
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Small Block Stroker question part 2 [Re: pittsburghracer] #1713291
12/21/14 02:18 AM
12/21/14 02:18 AM
RobX4406 Offline
RobX4406  Offline
568 at 3350 10.52
570 at 3200 10.36
529 at 3300 10.68
Most of those were with a set of tti or hooker 5204's and a 950 hp. Same as what was installed in the car. That dyno isn't the infamous westech lottery machine.
Cars ran those numbers. Are those not good et's for that HP... they sure are and the MPH was right in line.
Re: Small Block Stroker question part 2 [Re: RobX4406] #1713292
12/21/14 02:27 AM
12/21/14 02:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I just dont understand the OP reason to drop 35hp..
if he wants to.. put a smaller carb on it.. the engine
was/is a proven piece
Re: Small Block Stroker question part 2 [Re: MR_P_BODY] #1713293
12/21/14 02:54 AM
12/21/14 02:54 AM
MN
MN
I put a 641 HP motor in my car and it went 9.84 at 136 and put the car on the rear bumper leaving from 2000 rpm on a 9 in slick so I'm not looking to do that again. With 500 HP or went 10.43 so I figured 585 would get me low tens without the chance of wrecking the car.
Re: Small Block Stroker question part 2 [Re: dustyswinger] #1713294
12/21/14 02:59 AM
12/21/14 02:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Retard the cam some so you loose some torque and a
smaller carb.. and you can pull timing
Re: Small Block Stroker question part 2 [Re: dustyswinger] #1713295
12/21/14 03:00 AM
12/21/14 03:00 AM
RobX4406 Offline
RobX4406  Offline
{sarcasm}How ignorant and foolish of you to have a plan.{/sarcasm}
LOL
Re: Small Block Stroker question part 2 [Re: RobX4406] #1713296
12/21/14 03:03 AM
12/21/14 03:03 AM
PA.
"Little"John
"Little"John
PA.
Switch out the 1.65 rockers for a set of 1.5's
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Small Block Stroker question part 2 [Re: RobX4406] #1713297
12/21/14 03:08 AM
12/21/14 03:08 AM
MN
MN
To me that can seems big. I've thought about taking timing out of it but I don't know about taking HP out of a motor. I just think it might be easier on valve train parts with a smaller cam? Or am I wrong with that?
Re: Small Block Stroker question part 2 [Re: pittsburghracer] #1713298
12/21/14 03:10 AM
12/21/14 03:10 AM
MN
MN
It would be cheaper to buy a $315 roller can than buy a set of T&D rockers.
Re: Small Block Stroker question part 2 [Re: dustyswinger] #1713299
12/21/14 03:55 AM
12/21/14 03:55 AM
RobX4406 Offline
RobX4406  Offline
Yes it would.
Re: Small Block Stroker question part 2 [Re: dustyswinger] #1713300
12/21/14 07:54 AM
12/21/14 07:54 AM
Q
Quicktree Offline
Quicktree  Offline
Q
fix the dang chassis, dropping a few HP is not going to help. 585HP can do the same thing
Re: Small Block Stroker question part 2 [Re: dustyswinger] #1713301
12/21/14 12:50 PM
12/21/14 12:50 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Sounds to me like you need better shocks, not less power.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Small Block Stroker question part 2 [Re: B3422W5] #1713302
12/21/14 01:25 PM
12/21/14 01:25 PM
WHY ask us??? Ask the guy that built it--he knows what is best for that engine period.
Re: Small Block Stroker question part 2 [Re: ] #1713303
12/21/14 02:42 PM
12/21/14 02:42 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
With the smaller camshaft, it may launch just as hard. You will just have less at the top end.
