Re: Has anyone put piston oiler jets in a LA/R3 small block?
[Re: LSP]
#1712128
12/18/14 09:26 PM
12/18/14 09:26 PM
Posts: 656 Florida
CJD AUTOMOTIVE
The R5 program I was involved in used 3 squirters, 1 aimed at the exhaust pocket, 1 at the plug, 1 swept along the pin axis between the pin bosses as the piston moved from BDC to TDC. Squirter sizes were between .018"-.024".
I think 3 might be a tall order to fit inside the R3. I'm either shooting from the pan rail or snaking a tube along the webbing into the cylinder. I was going to aim at one side of the pin/piston bottom and angle the jet so it swept to the other side during the stroke. What is your opinion one using one and where to aim?
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: LSP]
#1712130
12/19/14 12:35 PM
12/19/14 12:35 PM
Posts: 656 Florida
CJD AUTOMOTIVE
If you can position the squirter to sweep the pin and the exhaust pocket area, that's about the best you can do with one squirter, lot of heat in that exhaust pocket with a turbo. Make sure your piston guy puts at least a .090" or more lower radius in the valve pockets and a .500" or more radius between them. High hp/heat wedge stuff likes to crack between the valve pockets.
Thank you. I appreciate your info. Luckily I run a dished piston without reliefs. So in theory, the heat shouldn't be isolated to a particular area, but should dissipate evenly through the smooth dish?
[Re: CJD AUTOMOTIVE]
#1712131
12/19/14 08:10 PM
12/19/14 08:10 PM
Posts: 3,519 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I have a couple of R3 blocks that have the piston oiling. Just a small hole through block to an oil passage. I blocked mine off as they would not have been a good deal on a drag race motor with low tension rings. Bill
Hi Bill,
I have an R3 as well. Do you have a pic of where the holes are located?
Thanks, Craig
Craig, I'll try to take some shots over the weekend and post them. Thanks, Bill
#1712132
12/20/14 12:47 AM
12/20/14 12:47 AM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
Yes, no pockets at all is even better.
#1712136
12/23/14 02:10 PM
12/23/14 02:10 PM
340Cuda
Tulsa, Oklahoma
Hi Bill,
Thanks, Craig
Photo attached, this is shot from the top of #7, the black dot is the plugged oiler.
Bill
[Re: 340Cuda]
#1712137
12/23/14 03:14 PM
12/23/14 03:14 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Don't think I have. The block I had looks just like the above picture posted.
